| » Whirlpool washer smells moldy whenever idle |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Quote:
__________________
regards jim |
My washer is a Bosch WFK2401. I have seen some nasty pictures of the outside of the inside drum as well as the inside of the outside tub showing a thick layer of scum impregnated with mold. Is this the exception or the rule? Also some posters have talked about the internal hoses being gunked up like blocked coronary arteries. It appears that hard water, too much soap and lots of fabric softener aggrevate this problem which is not situation but I always close the door and have never wiped the seal (until reading up on the subject).
I am trying to understand how bad the problem may be where I cannot see in the machine. I would just crack the case and take a look but the unit is installed in a boat and r/r is a bear. Also, I have to be very careful what chemicals that I use because I am sensitive. Thanks, George |
The source of mold is usually caused by using Too much detergent. You should only be using about 2 tablespoons of HE detergent per load. When you over soap your machine not all the detergent gets rinsed out, this leaves a film on the inside of the machine which breeds the mold. The quick test to determine over-soaping is to run a rinse cycle with no clothes in the machine. if you see suds, you're using too much soap.
This info was bestowed to me by one of the factory techs at LG. |
I have had front loading washers most of my life.the first one was a 1956 Westinghouse Laundromat.In the Laundrofile use and care book, it specificaly states you need to leave the door ajar(slightly open)to keep the interior fresh and eliminate any chances of mildew forming.I always leave mine open when not in use for at least 8 hours(overnight)and have yet to see or smell any fowel oders.If you had to go somewhere a few months and didn't need to keep anything in your refrigerator turning it off to save energy,would you not keep it open to keep mold and mildew from forming and smelling up its interior???Same principal.Like a refrigerator,front loader's interiors are air tight.If that humidity from the steam and water inside has nowhere to go and can't evaporate,it stagnates and causes mildew on all the plastic and rubber parts inside.
I agree with those that say leave the door ajar. My front load washer has never had a bad moldy smell and I do leave the door adjar. Also the manufacturers do recommend that once a month use about a cup of bleach in the washer (empty load).
I'd also like to note that most washer that smell are the ones that primarily use liquid detergents and fabric softeners. A lot of those have an animal base in them, thus it is more or less rotting inside the machine when not flushed out all the way. I only use powder detergents and use dryer sheets (which of course can clog the lint screen, but an old tooth brush and dish soap takes care of that.) We have also ran into the problem once, of a customer having a foul smell and after thorough inspection we found that the drain tube where they placed the hose into was too low and their hose was down into the drain too far pulling the dirty water from the pee trap back into their machine. Nat |
Leaving the door cracked is a good idea. But, with the door closed, a front loader is not air tight like a refrigerator. The tub is vented through the detergent injector, and most are also vented through the back of the case.
| Display Modes | |
| whirlpool washer | farina | Washer Repair | 2 | 01-30-2008 06:24 PM |
| dryer smells | ginny | Dryer Repair | 2 | 10-20-2007 02:42 AM |
| refrigerator smells and water in bottom | jim | Refrigerator & Freezer Repair | 1 | 10-17-2007 11:42 AM |
| Speed Queen hums and something smells hot | help_me_please | Washer Repair | 2 | 09-18-2007 12:47 PM |
| whirlpool washer | diggerette | Washer Repair | 1 | 08-27-2007 07:59 PM |
