Discuss
Whirlpool washer smells moldy whenever idle
 in
Washer Repair
I too had a terrible odor problem with my Whirlpool Duet washer. I tried wash cycles with bleach, leaving the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer smells moldy whenever idle
  #61 (permalink)
Old 06-06-2013, 09:15 AM
Junior Member
oxbow37 is on a distinguished road
Default Washer Smell
I too had a terrible odor problem with my Whirlpool Duet washer. I tried wash cycles with bleach, leaving the door open between loads, cleaning the soap dispenser, wiping the door gasket with bleach and scrubbing the inside of the drum to no avail. I was talking to my next door neighbor and mentioned the problem with my washer. He told me that he experienced the same problem but had fixed it with a device called the Washer Fan.
It seems that all front and top load HE washers have a design flaw that allows water to remain in the drum between loads of wash. The Washer Fan attaches to the rear vent of the washer with magnets and circulates air to get rid of the mold causing humidity which causes the smell. I ordered the device, installed it (took about 1 minute) and within 4 days the smell was gone! I can't say enough about Washer Fan....you can find them online at: Home
  #62 (permalink)
Old 06-24-2014, 07:30 AM
Junior Member
zjtins is on a distinguished road
Default How to prevent build up in front loader
Too much soap or softener builds up in the low water machines.
Unless your clothes have ground in dirt, and are just daily wear, then use 1/4 or less of the soap and make sure it has the HE on the bottle... do not use powdered soap, takes too long to dissolve. Also add 3 Tbsp of Borax, to the soap dispenser.
For softener I use a 1 qt vinegar bottle with 2 oz of softener the rest white vinegar. Fill your dispenser as normal. The vinegar helps get rid of any soap residue on you clothes and any vinegar smell goes away with drying.
  #63 (permalink)
Old 04-17-2015, 10:42 PM
Junior Member
ApplianceQueen is on a distinguished road
Default
Try using the Tide HE TURBO-- They are amazing. It take off about 3 minutes off my wash cycle. It suds even less than the regular HE.
  #64 (permalink)
Old 06-05-2015, 09:00 AM
Junior Member
thalthal is on a distinguished road
Default Cleaners
They do have different cleaners you can run through the wash to get rid of that nasty smell. I would also make sure that everything looks clean in the washer. Sometimes you get a mold buildup if water pools in there too long. You shouldn't have to worry too much just clean it out and continue your load of laundry. If the problem continues I would talk to the manufacturers. Kitchen Cabinets in the Hamilton Area
  #65 (permalink)
Old 09-03-2016, 02:37 PM
Junior Member
alisam is on a distinguished road
Default
Quote:
Originally Posted by JaneWEllis View Post
Hello --
I see mold inside the large rubber ring (the seal) at the opening of my washer and it's hard to scrub off, even with bleach. Will the product some of you have mentioned (Affresh?) reach that mold if I use it? Thank you for help on this; it's driving me crazy.
Thank you for helping to repair washing machines Whirlpool
  #66 (permalink)
Old 11-04-2016, 12:36 PM
Junior Member
Sean.B is on a distinguished road
Default
Hello --
It is very hard to get rid of the mold. most of the time it is imposable. I would replace the door boot seal.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer smells like something is burning D Will Washer Repair 4 08-06-2011 09:42 AM
Whirlpool spins agitates intermittently, smells tbyers31 Washer Repair 9 09-26-2009 04:54 PM
whirlpool washer smells like smoke and takes a dump inkslinger00743 Washer Repair 4 03-16-2009 04:09 AM
washer smells moldy all the time calfpen Washer Repair 5 02-11-2009 05:37 PM
musty, moldy smell coming from washer peterbsc Washer Repair 0 05-09-2008 02:23 PM
