Discuss
Whirlpool washer smells moldy whenever idle
 in
Washer Repair
Try not to use bleach..Find some Washer Magic..This may help. Also, can you post your Model# so we
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer smells moldy whenever idle
  #11 (permalink)
Old 01-11-2008, 04:14 PM
bentwrench1999 bentwrench1999 is offline
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Arrow Moldy front-loading washing machine
Try not to use bleach..Find some Washer Magic..This may help. Also, can you post your Model# so we can see which machine you have? wrench
__________________
  #12 (permalink)
Old 01-11-2008, 06:42 PM
JaneWEllis JaneWEllis is offline
Junior Member
JaneWEllis is on a distinguished road
Default Answer to Bentwrench re: moldy smell
Hello Bentwrench,
Thank you for your response. I bought this washer in September, 2001. It is GE Model WSXH208A1WW. I'm not sure if I need to replace the big rubber seal or if one of these cleaning products will do the trick.
  #13 (permalink)
Old 01-11-2008, 06:46 PM
Junior Member
Default To Bentwrench (again)
I can see gray, moldy-looking residue inside the rubber ring/seal and it smells moldy. Washer Magic's ads refer to lime deposits, but don't mention mold. Will it work as well as the other product mentioned in this thread?
Thanks again.
  #14 (permalink)
Old 01-11-2008, 07:08 PM
Senior Expert
APP Volunteer
Exclamation Whirlpool washer smells moldy whenever idle
Hi..mold and mildew problems are common in front load washers. What I do to my Neptune Front Loader is I use 1 cup of Cascade detergent and run the machine through a complete cycle.Check to make sure the boot drain hole is clear of lint. Water needs to drain back into the tub or it WILL mildew.good luck..wrench
__________________
  #15 (permalink)
Old 01-11-2008, 07:30 PM
Junior Member
Default For Bentwrench - re: lint
Thanks again for your help on this. Sorry I'm so ignorant, but I'm not sure where the drain hole is and I'd like to look for any lint and clean it out per your advice. Can you tell me?
  #16 (permalink)
Old 01-16-2008, 10:54 AM
Senior Expert
APP Volunteer
Thumbs up For Bentwrench - re: lint
Open the door and look inside at the bottom of the opening. There is a rubber boot that's capable of holding water. Look for a whole about 1/4" in diameter and make sure it's clear of junk. Then Find a packet of Affresh. This is a chemical used to clean mold and mildew. I've heard it does a wonderful job..wrench
__________________
  #17 (permalink)
Old 01-16-2008, 11:06 AM
Junior Member
Thank you. I have looked there and see many holes in the rubber, rather than one. So I'm simply cleaning anything that looks like it might be "the" drain hole, if it's only one on my model's boot. I ran the washer 2 times with Cascade which helped a lot, but there's a built-up of smudge that I am also trying to get out with paper towels and Q-tips. If you think Affresh will do the trick better than Cascade, I will certainly try it. And I really really appreciate your help.
  #18 (permalink)
Old 01-19-2008, 11:33 AM
GeorgeG GeorgeG is offline
Member
GeorgeG is on a distinguished road
Default
Where does this moldy "gunk" accumulate? Is it in the outer tub, pumps, hoses, etc? My only option may be opening up the washer (Bosch WFK2401) and mechanical removal as I cannot use chemicals for cleaning. It took 6 years for the smell to show up in my washer. I smell it outside the unit when running. Can the gunk be outside of the water flow?
Thanks,
George
  #19 (permalink)
Old 01-19-2008, 08:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi George,
The Affresh specifically designed for a front load washer. Why you can not use it on yours?
__________________
  #20 (permalink)
Old 01-20-2008, 01:37 PM
Junior Member
Default Accumulation of "gunk"
In my front-loading machine, the gunk accumulated in the rubber boot between the door and the tub. You have to peal it back to see the underside and the crevices where it's moldly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer farina Washer Repair 2 01-30-2008 07:24 PM
dryer smells ginny Dryer Repair 2 10-20-2007 03:42 AM
refrigerator smells and water in bottom jim Refrigerator & Freezer Repair 1 10-17-2007 12:42 PM
Speed Queen hums and something smells hot help_me_please Washer Repair 2 09-18-2007 01:47 PM
whirlpool washer diggerette Washer Repair 1 08-27-2007 08:59 PM
