Discuss
LG pump may be bad or have something stuck
 in
Washer Repair
How do I get to the pump on this machine? I cant see a way to take the face plate
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG pump may be bad or have something stuck
  #1 (permalink)
Old 10-20-2007, 09:19 AM
Jamiepe Jamiepe is offline
Junior Member
Jamiepe is on a distinguished road
Default LG pump may be bad or have something stuck
Model Number: WM2277CW   Brand: -brand-   Age: Less than 1 year
How do I get to the pump on this machine? I cant see a way to take the face plate off the front loader.
Do I go in from the bottom?
Shesh...they don't want me to do it obviously...there is no easy way in. From the back is easy but you cant reach the pump
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-20-2007, 11:27 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Is there not a cover on the bottom left side that you can flip open?
Open that cover and you can clean the water pump out from there.
This LG Manual may help.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
  #3 (permalink)
Old 10-24-2007, 11:16 AM
Junior Member
Default All set now
For the LG front loading washer you have you have to attack the pump from the bottom. Yes, you remove the small face plate to the filter on the front and remove the screws there but that does not allow access to pull the pump. Do not attempt to remove the entire front of the machine.....it is not the way you want to do this job.
When Underneath the unit you have to remove the storage unit if you have one which exposes an open hole on the bottom of the washer. When inside and you can see the pump, you need to undo 3 clamps that attach rubber hoses from the pump to to other parts of the machine. Then I had to detach the wiring attached to the pump (took a picture of that) and the pump should come out by sliding it out of its mounting track . We opened the pump itself from the enire component by losening the 3 screws that attached it tto the motor and found a USA penny in there keeping the pump turbine from being able to spin which was causing the spin cycle not to work and hence not allowing the machine to drain. I am amazed that a penny was able to make it past the filter. I figure it snuck pat one time possibbly when I pulled the filter itself to clean it and it may have drained unabated into the pump. It took about 2 hours to take it apart and diagnose with 2 people. .....on a Saturday .....not what I had in mind.
Note..better to do it with 2 people...one to support the pump while the other person undoes the hose clamps.
I reccomend when doing the job to lay the unit on its side which exposes the bottom of the machine and allows you to remove the back of the washer(4 screws) to make it easier for 2 people to work on the unit. W/o 2 people, putting on and off the clamps to the hoses would be too hard since they are a PITA to get on/off w/o a person holding the pump for the guy putting the clamps on.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cycle monitor stuck on clean.. LATONYA007 Dishwasher Repair 2 12-30-2007 09:08 PM
Drum won't turn, nothing stuck..... tbrunson Washer Repair 1 10-10-2007 03:47 AM
Ice Flap Stuck! Tom Lambertv Refrigerator & Freezer Repair 0 10-01-2007 05:12 PM
my dryer sounds like a stuck pig Tina Dryer Repair 0 09-03-2007 09:22 PM
Basket Seems Stuck Nick Washer Repair 0 07-25-2007 06:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
