Discuss
Kenmore washer agitates but will not spin, why?
 in
Washer Repair
Washer Details: Manufacturer: Kenmore Model #: 110.22942100 On a regular cycle the washer tub fills up according to the load
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer agitates but will not spin, why?
  #1 (permalink)
Old 02-27-2011, 05:29 PM
Junior Member
theking4u is on a distinguished road
Exclamation Kenmore washer agitates but will not spin, why?
Model Number: 110.22942100   Brand: Kenmore   Age: 5 - 10 years
On a regular cycle the washer tub fills up according to the load and starts to agitate. When I put it in a spin cycle, the water drains and I hear the motor making noise, but the tub will not spin, so the cloths will stay drenched. This implies the Switch is working, since the motor is spinning and stops making noise when I open the lid.
I took out the motor, clutch and transmission assembly, when I spin the motor clockwise, the clutch starts to spin, so the transmission is okay.
The plastic actuator is also not broken.
Now there are two things that could be bad: the clutch or the brake.
What should I do to see which of these are broken? What physical damage should I look for? Is there is something else?
Thank you for any help, I have spent all day trying to fix it.
The brake coupler is also not broken or worn out.
Ads By Google
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
  #2 (permalink)
Old 02-27-2011, 08:15 PM
Junior Member
Default
So now it is spinning but it seems unbalanced. I have made a video of this check it out:
YouTube - Kenmore Elite Washer making weird noises while spinning
  #3 (permalink)
Old 02-28-2011, 03:53 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You probably have a worn clutch and bad brake shoes. If it still shakes when the washer is empty, you may have suspension problems, just check the springs.
You can do the tranny coupler test in my sticky, "replacing direct drive washer brake shoes".
__________________
  #4 (permalink)
Old 02-28-2011, 01:17 PM
Junior Member
Default
Here are some pics of the brake and clutch. One other thing I noticed was that when I turned the tranny couple the, the tranny does not turn continuously, is that normal.
Last edited by theking4u : 02-28-2011 at 01:20 PM. Reason: Picture links did not work
  #5 (permalink)
Old 02-28-2011, 02:41 PM
Junior Member
Default
thank you so much for your time and help.
When I spin the tranny couple couter-clockwise, it agitates normally, but when I spin it clockwise, it rotates for a while and then it stops and starts to rotate again.
So is it just the tranny then or should i still just replace the clutch? Should I open up the transmission and see if there are broken gears or something? Thanks again.
  #6 (permalink)
Old 03-01-2011, 03:24 AM
Senior Expert
APP Volunteer
Default
You probably have a partially stripped nylon gear in the tranny, you can take it apart to confirm.
__________________
  #7 (permalink)
Old 03-01-2011, 01:16 PM
Junior Member
Default
Okay I took it apart, but I need that special tool to take of the retaining ring. Hopefully I can replace the nylon gear, otherwise I am probably gonna buy a second hand washer. Thanks for the help.
  #8 (permalink)
Old 03-01-2011, 02:44 PM
Senior Expert
APP Volunteer
Default
You just pry it off with a flat blade screwdriver.
__________________
  #9 (permalink)
Old 03-01-2011, 03:17 PM
Junior Member
Default
Richappy are you talking about the big plastic gear or some other gear under that one?
  #10 (permalink)
Old 03-01-2011, 03:22 PM
Junior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer agitates but won't spin` mls6089 Washer Repair 1 01-08-2012 04:53 PM
washer agitates but will not spin out basee5 Washer Repair 0 08-26-2010 12:17 PM
Kenmore 90 series agitates and drains but won't spin stormspotter Washer Repair 2 02-16-2010 08:46 AM
Kenmore 90 series washer agitates, drains but it Won't SPiN ! selcukbey Washer Repair 3 05-19-2008 11:27 AM
Washer agitates, but doesn't spin Cerickson Washer Repair 0 01-05-2008 10:57 AM
