Discuss
GE washer won't spin
 in
Washer Repair
Washer cycles and drains fine but it only spins for about 5 seconds.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer won't spin
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-19-2007, 03:50 PM
hart7220 hart7220 is offline
Junior Member
hart7220 is on a distinguished road
Default GE washer won't spin
Model Number: wcse3100a1ww   Brand: GE   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-19-2007, 04:19 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi hart7220
Most likely the problem with your washer is a bad control board. It's not repairable and has to be replaced.
- The part number for the new control assembly AP3140343
- Here are the break down diagrams for the GE washer Model WCSE3100A1WW
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 10-19-2007, 04:25 PM
Junior Member
Default
Thanks so much Gene , the part has been ordered!
  #4 (permalink)
Old 10-19-2007, 04:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #5 (permalink)
Old 10-20-2007, 03:18 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
GE has had a lot of problems with motors. Before replacing control board, which might just blow out when you turn on the washer, check the motor current, if over 10 amps, you have a shorted centrifical switch in the motor. You can click on your model # to order it.If you remove front panel and measure voltage to the motor. If ok when it shuts off this confirms new motor time.
__________________
  #6 (permalink)
Old 10-22-2007, 06:02 PM
Junior Member
I got a new control board and still have the same problem. If the centrifical switch is bad doe's that mean that I need a whole new motor? Please help, thanks, Neal.
  #7 (permalink)
Old 10-22-2007, 06:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
GE does not sell parts for the motor separate which means you have to buy the whole motor with the clutch assembly.
- The part number for the motor AP3160670
__________________
  #8 (permalink)
Old 10-22-2007, 06:20 PM
Junior Member
Default
Do you think it's worth putting this kind of money into this machine?
  #9 (permalink)
Old 10-22-2007, 06:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Depends on the age and condition.
__________________
  #10 (permalink)
Old 10-24-2007, 04:24 PM
Junior Member
Default
Just wanted to let you know that the spin cycle is now working. Could the motor still possibly be a problem? Thanks, Neal.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin chevy2 Washer Repair 6 03-10-2008 12:47 PM
washer won't spin dmcleer Washer Repair 12 11-02-2007 04:28 AM
Washer will not spin Darren Washer Repair 4 10-26-2007 01:41 PM
washer won't spin Craig Washer Repair 1 09-30-2007 08:33 PM
Washer won't spin arnoldte Washer Repair 1 09-19-2007 09:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
