| » Washer drains, won't spin without help |
Model Number: 100 22922 100 Brand: Kenmore Age: 5 - 10 years
Kenmore 90 Series, M# 100 22922 100. Washer fills and agitates fine, during rinse/spin cycles tub does not spin, water does drain out. If you "help" it by manually turning the tub and starting/stopping it after it starts to spin (it moves slowly), you can here it engage (light clunk) and it will usually spin/rinse fine.
Does not always happen, sometimes complete cycle will process. Other times, no movement during spin-type cycles. Prior issues with similar washer was failed coupling, coupling is not issue this time, checked. No visible gear lube leaks, no odd noises, no water/fluid leaks. Timers move and go thru entire cycle. This is a washer about 6 years old, but only runs about 4 loads (medium size at that) per week. Help!!1 Ads By Google Related Models |
| Display Modes | |
| Washer drains will not spin | wallace815 | Washer Repair | 2 | 02-01-2010 08:05 AM |
| washer drains but will not spin | tedpuhl | Washer Repair | 0 | 01-31-2010 09:59 AM |
| Spin Dry Cycle - Washer drains but tub doesn't spin | JARG | Washer Repair | 3 | 11-23-2009 09:22 AM |
| Washer drains but won't spin | KAP | Washer Repair | 3 | 11-09-2007 11:59 AM |
| Washer will not spin but drains, etc. | xevier69 | Washer Repair | 0 | 07-31-2007 08:05 AM |
