Discuss
Remove cabinet to access drain pump & hose
 in
Washer Repair
I need to open the cabinet of my Kenmore Calypso washer, so I can unclog the drain hose & pump.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Remove cabinet to access drain pump & hose
  #1 (permalink)
Old 02-25-2011, 04:40 PM
Junior Member
Hpaul is on a distinguished road
Default Remove cabinet to access drain pump & hose
Model Number: 110.24086200   Brand: Kenmore   Age: 1 - 5 years
I need to open the cabinet of my Kenmore Calypso washer, so I can unclog the drain hose & pump. There are no screws at the corners of the control panel like some washers have. How can I remove the cabinet?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 02-25-2011, 04:54 PM
Member
murderurfriends is on a distinguished road
Default
You wanna do this by tipping the machine back and there are 3-5/16" screws on the bottom plate..the cabinet does not come off like prior kenmores if you use a flat blade between prant panel and top there are a latch on the left and right and the lid flips up. Before tipping the machine back get as much water out of it as possible or it will come out the suds overflow. When that machine looks empty there is still about 3 gallons of water In it the old style pump is just like the older ken mores and the new one has 3 torx to take off and you clean very easily. But again can't stress enough there's is quite a bit of water in that machine even when it looks like theres not
  #3 (permalink)
Old 02-25-2011, 05:13 PM
Junior Member
Default Remove cabinet to access drain....
Quote:
____
Thanks. I greatly appreciate your help!
  #4 (permalink)
Old 02-25-2011, 05:15 PM
Member
Default
Not a problem check back let us kno how it went!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Drain Hose Access gerald_dain Dishwasher Repair 3 11-11-2010 06:11 PM
How do I access the drain hose suzq53 Dishwasher Repair 1 10-30-2010 03:30 AM
Steps needed to remove drain pump lss124 Washer Repair 3 11-29-2009 06:24 PM
How do I Remove cabinet to get to pump edmgriffin Washer Repair 1 04-13-2009 08:06 AM
Washer Drain Pump Hose vikingollie Washer Repair 1 03-29-2009 02:29 PM
