| » Frigidaire Affinity won't complete cycles |
Model Number: AFT6000FS2 Brand: Frigidaire Age: 1 - 5 years
My washer keeps pausing between cycles. We are pretty sure it has a clog somewhere. We have checked the drainage pipe and nothing is there so we believe it is inside the pumps but can't figure out how to get to the pumps to see if the problem is there. How can we get to the pumps and if the problem isn't in the pumps what else could make our machine constantly pause and not spin out all the water?
We will need a proper model number to help you with this. The model you provided is not working.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
If you pull the washer out, there is an access panel on the back of the washer. Remove this panel, and you will see the pump. There is a hose that runs from the pump to the tub. Remove this hose and check the filter cup. Most likely this is where your problem is. Hope this helps.
__________________
| Display Modes | |
| Frigidaire Affinity Paused | craftkween | Washer Repair | 2 | 10-21-2011 10:04 AM |
| will not complete cycles | tstallman | Washer Repair | 0 | 01-29-2011 12:40 PM |
| Waher won't complete cycles | parrishfam | Washer Repair | 7 | 12-30-2010 09:21 PM |
| Frigidaire Affinity Drier | billscov | Dryer Repair | 1 | 05-18-2009 01:19 PM |
| Frigidaire affinity | mrsakman | Dishwasher Repair | 1 | 10-23-2008 07:43 PM |
