| » water does not come out |
Model Number: RAS6233KQ0 Brand: Roper Age: 1 - 5 years
my washing machine stops at the point where it should release the water. the water does not come out at all. could it be a problem with the time? please advise before i purchase a timer. thank you.
I Have A Whirlpool Top Loading Machine, Its A Special Edition, 6 Cycle,2 Speed Motor.heavy Duty Extra Large Capacity. Machine Works Fine Until It Is Time For The Water To Spin Out Of The Tub. It Does Absolutely Nothing,as Far As The Water Coming Out. I'd Like To Know What The Problem Could Be, And What I Can Do To Correct The Problem.
Thank You |
Hi John
Does it drain? Also, in order to provide the best accurate advise I need you to post the complete model number of your washer. You can find it under the lid. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hi Grace
Most likely the problem with your washer is a bad lid switch. Does it click when you slowly open or close the lid? If the answer is "No" then no doubt the lid switch has to be replaced. - The part number for the new lid switch AP3100003 - Here are the break down diagrams for the Roper washer Model RAS6233KQ0 Good luck. Gene.
__________________
| Display Modes | |
