Basically it just stopped working the other day. It filled with water than stopped. I took it apart and found that the blue and orange wires had somehow fused together about two inches above the connector. Fixed that but nothing. I can fill it with water but the fill valve makes a buzzing noise. Is it possible that the fill valve is stuck and wont close so there is no continuity of power?
