We Start The Washer And The Necessary Water Gets Fill Up To Run However, Nothing Happens. We Tried To Start The Cycles Manually And The Washer Still Does Not Runs.
Do You Have Any Suggestion To This Problem.
Regards,
Joe F
A common failure is the lid switch. I would check there first.
The Problem Was Resolved You Were 100 Percent On The Money.
We Replaced The Lid Switch.
Regards,
Joe F
