| » Washer won't spin |
Model Number: 110 Brand: Kenmore Age: More than 10 years
Hello
I have a Kenmore washer that will not spin. It went through it's cycles but at the spin cycle there is a slight noise coming from the motor but no smells of any kind. I can turn the agitator freely with little effort if that means anything. I loosened the console and flipped the cabinet forward and could not see or smell anything unsual (not that I would know if I did Sears Kenmore model 110 91320100 Stock 13201 Serial # CC4729830 It was purchased new in 1992 or '93 Thanks! Jim Ads By Google Related Models |
Hi Jim,
The first thing I would do is check the pump for a foreign object inside which cause the pump to stuck. In order to it you have to remove the washer cabinet. You can find the instructions attached to this reply. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| whirlpool washer won't spin manually or spin | boniam | Washer Repair | 15 | 06-29-2008 07:19 AM |
