I need to replace the water saver/water mizer, two-way valve, part #359985. The valve is supposedly no longer available. It has been replaced by part #285144. I tried the replacement valve without success. There was no way that I could make the replacement work. Is there anyone that can supply the original valve, part #359985?
Thank you.
