whirlpool, cabrio is leaking out the motor housing. anyone have experience with this?
Originally Posted by: jimoo1 whirlpool, cabrio is leaking out the motor housing. anyone have experience with this? Jim, Yes, several of us have, You most likely have a damaged tub bearing seal, or a cracked tub(not likely). You'll need to order and replace the outer tub assembly Part number: AP4316595
The kit should contain a new tub, drive shaft, pre set bearings, and seal. It'll probably take you approximately 60 minutes to due the repair, and you can do it with basic hand tools. :) :) :)
