Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer leaks (http://forum.appliancepartspros.com/washer-repair/17670-washer-leaks.html)
allen9258 12-18-2008 08:47 PM
washer leaks
i need some advice on this my washer is leaking on the floor when i start the wash cycle and i can tell that the water is comming from the tub, so just what is causing this and what do i need to repair this and is it very hard to repair? are there any special tools that i will need, water is leaking above the tranny and i was told that it is a tube seal. also i read that a spander wrench was needed, i so what does it look like and where can i find one?
libertyappl 12-18-2008 08:51 PM
This is a Spanner wrench
Nat
allen9258 12-20-2008 10:10 AM
I was told that on this washer it would be best to throw it away because it is not worth the time, money and repair. what is a estimate of the time and difficulty to replace the seal. Can you also give me a part number and the cost of the seal?
libertyappl 12-20-2008 10:44 AM
It could be the Hub & seal or Triple lip seal/hub k depending on the series number of the washer. It would probably take a few hours to do.
Nat
