Discuss
Whirlpool Washer noise on high spin
 in
Washer Repair
Washes fine, but during high spin cycle emits constant hum/squeal noise. Does not do this during agitation nor low spin.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer noise on high spin
  #1 (permalink)
Old 02-21-2011, 05:32 PM
Junior Member
dmmetzger is on a distinguished road
Default Whirlpool Washer noise on high spin
Model Number: LSQ9500LQ0   Brand: Whirlpool   Age: 5 - 10 years
Washes fine, but during high spin cycle emits constant hum/squeal noise. Does not do this during agitation nor low spin. Took cabinet off and sounds like it is coming from the motor up front. Possilbe the high speed motor part causing this? What is most likely cause or part to repair? Will a new motor fix this. Thanks.
Related Models
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
  #2 (permalink)
Old 02-22-2011, 07:06 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
It could be the pump causing the noise. To test this lets remove the pump from the front of the motor, and spin it out with no water in it. See if the noise is gone. If so check and see if something is in the pump. If not then replace the pump. Here is the part number as well as a link to the parts diagram. Hope this helps. Part number: AP2907492
Brake, clutch, gearcase, motor & pump replacement parts for WHIRLPOOL LSQ9500LQ0 | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Whirlpool Washer Will Not Go Into High Spin davcinoz Washer Repair 2 08-07-2010 06:29 AM
High pitched noise Whirlpool top load washer veralynn Washer Repair 1 02-27-2010 05:33 PM
Whirlpool washer will not high spin odomfl Washer Repair 0 12-15-2008 04:58 AM
Whirlpool Imperial Washer making high pitch noise Minickhk Washer Repair 0 01-11-2008 07:36 AM
