Discuss
Kenmore Front Load Washer
 in
Washer Repair
The machine has a code F-1 and I need to know which board needs to be replaced. I read that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Front Load Washer
  #1 (permalink)
Old 02-21-2011, 05:29 PM
Junior Member
Kenneth C is on a distinguished road
Default Kenmore Front Load Washer
Model Number: 11047561601   Brand: Kenmore   Age: 1 - 5 years
The machine has a code F-1 and I need to know which board needs to be replaced. I read that it could be the control board or the control unit.
Thank you
Related Models
Kenmore 11047561601 RESIDENTIAL WASHER
Kenmore 11047561602 RESIDENTIAL WASHER
Kenmore 11047561603 RESIDENTIAL WASHER
Kenmore 11047561604 RESIDENTIAL WASHER
Kenmore 11047562700 RESIDENTIAL WASHER
Kenmore 11047566600 RESIDENTIAL WASHERS
Kenmore 11047566601 RESIDENTIAL WASHER
Kenmore 11047566602 RESIDENTIAL WASHER
Kenmore 11047566603 RESIDENTIAL WASHER
Kenmore 11047567700 RESIDENTIAL WASHER
Kenmore 11047567701 RESIDENTIAL WASHER
Kenmore 11047571600 RESIDENTIAL WASHERS
Kenmore 11047571601 RESIDENTIAL WASHER
Kenmore 11047571602 RESIDENTIAL WASHER
Kenmore 11047571603 RESIDENTIAL WASHER
Kenmore 11047571604 RESIDENTIAL WASHER
Kenmore 11047572700 RESIDENTIAL WASHERS
Kenmore 11047576600 RESIDENTIAL WASHERS
Kenmore 11047576601 RESIDENTIAL WASHER
Kenmore 11047576602 RESIDENTIAL WASHER
Kenmore 11047576603 RESIDENTIAL WASHER
Kenmore 11047577700 RESIDENTIAL WASHER
Kenmore 11047577701 RESIDENTIAL WASHER
Kenmore 11047581600 RESIDENTIAL WASHERS
Kenmore 11047581601 RESIDENTIAL WASHER
Kenmore 11047581602 RESIDENTIAL WASHER
Kenmore 11047581603 RESIDENTIAL WASHER
Kenmore 11047581604 RESIDENTIAL WASHER
Kenmore 11047602940 WASHER
Kenmore 11047661950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047662950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047701800 RESIDENTIAL WASHER
Kenmore 11047701801 WASHER
Kenmore 11047711800 RESIDENTIAL WASHER
Kenmore 11047711801 WASHER
Kenmore 11047751800 WASHER
Kenmore 11047751801 WASHER
Kenmore 11047761800 RESIDENTIAL WASHER
Kenmore 11047761801 WASHER
Kenmore 11047781700 RESIDENTIAL WASHER
Kenmore 11047781701 RESIDENTIAL WASHER
Kenmore 11047781702 WASHER
Kenmore 11047787800 WASHER
Kenmore 11047787801 WASHER
Kenmore 11047788800 WASHER
Kenmore 11047788801 WASHER
Kenmore 11047789700 RESIDENTIAL WASHER
Kenmore 11047789701 RESIDENTIAL WASHER
Kenmore 11047789702 WASHER
Kenmore 11047791700 RESIDENTIAL WASHER
Kenmore 11047791701 RESIDENTIAL WASHER
Kenmore 11047791702 WASHER
Kenmore 11047797800 RESIDENTIAL WASHER
Kenmore 11047797801 WASHER
Kenmore 11047798800 RESIDENTIAL WASHER
Kenmore 11047798801 WASHER
Kenmore 11047799701 RESIDENTIAL WASHER
Kenmore 11047799702 WASHER
Kenmore 11047852700 WASHER
Kenmore 11047852701 RESIDENTIAL WASHER
Kenmore 11047852702 RESIDENTIAL WASHER
Kenmore 11047852703 RESIDENTIAL WASHER
Kenmore 11047882700 WASHER
Kenmore 11047882701 RESIDENTIAL WASHER
Kenmore 11047882702 RESIDENTIAL WASHER
Kenmore 11047882703 RESIDENTIAL WASHER
Kenmore 11048182790 AUTOMATIC WASHER
Kenmore 11048182791 AUTOMATIC WASHER
Kenmore 11048184790 AUTOMATIC WASHER
Kenmore 11048184791 AUTOMATIC WASHER
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11049962600 WASHER
Kenmore 11049962601 RESIDENTIAL WASHER
Kenmore 11049962602 RESIDENTIAL WASHER
Kenmore 11049962603 RESIDENTIAL WASHER
Kenmore 11049972600 RESIDENTIAL WASHER
Kenmore 11049972601 RESIDENTIAL WASHER
Kenmore 11049972602 RESIDENTIAL WASHER
Kenmore 11049972603 RESIDENTIAL WASHER
Kenmore 1105062110 WASHER
Kenmore 110508802 KENMORE ELECTRIC DRYER
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 1105801100 KENMORE WRINGER WASHER
Kenmore 1105801200 KENMORE WRINGER WASHER
Kenmore 1105802301 KENMORE WRINGER WASHER
Kenmore 1105802330 KENMORE WRINGER WASHER
Kenmore 1105802331 KENMORE WRINGER WASHER
Kenmore 1105802400 KENMORE WRINGER WASHER
Kenmore 1105802600 KENMORE WRINGER WASHER
Kenmore 1105802601 KENMORE WRINGER WASHER
Kenmore 1105802700 KENMORE WRINGER WASHER
Kenmore 1105802701 KENMORE WRINGER WASHER
Kenmore 1105802800 KENMORE WRINGER WASHER
Kenmore 1105802801 KENMORE WRINGER WASHER
Kenmore 1105802901 KENMORE WRINGER WASHER
Kenmore 1105802910 KENMORE WRINGER WASHER
Kenmore 1105803000 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1105804100 KENMORE AUTOMATIC WASHER
Kenmore 1105804200 KENMORE AUTOMATIC WASHER
Kenmore 1105804201 KENMORE AUTOMATIC WASHER
Kenmore 1105804202 KENMORE AUTOMATIC WASHER
Kenmore 1105804203 KENMORE AUTOMATIC WASHER
  #2 (permalink)
Old 02-22-2011, 12:35 PM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
First try a hard reset by unplugging the machine for 30 min. If it still happens you will need the CCU. Part number: AP4434553
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Load Washer HE 4t Ladpol Washer Repair 1 02-14-2010 07:48 AM
Kenmore Front Load Washer Won't Run nsmslf4 Washer Repair 0 02-09-2010 08:11 AM
Kenmore Front Load Washer 4Ht hvaliquette Washer Repair 1 02-12-2009 04:39 AM
kenmore front load washer mattsea Washer Repair 1 01-11-2009 03:29 PM
Leaky Kenmore Front Load Washer Ericonline Washer Repair 8 01-11-2009 09:33 AM
