Hello,
During rinse or water fill-up cycles, water leaks from the front of the washer at the 6 o'clock position. There is a small crack on the bellows kit which I have managed to repair but water still leaks out. When looking at it closely, I noticed that water flows from the top of the bellows kit (12 o'clock) position straight down to the glass door and then leaks out. Do I need to replace my bellows kit? If so, do I just need the kit or any additional parts.
Thanks for the advice.
