| » GE Spacemaker washer seal replacement |
Model Number: wsks2060w1wh Brand: GE Age: 1 - 5 years
An apartment technician, I have 100 of these machines. The tub seals are starting to leak and I cannot figure out how to get the shaft out of the tub. There is no spanner nut like regular washers. I've gotten the agitator off and the tub loose but can't figure out how the shaft attaches. I cannot pull the tub off of the shaft and I wonder if it is"pressed" into the hub drive.
Ads By Google Related Models Last edited by Dennis Botelho : 12-18-2008 at 02:02 PM. |
Go to www.applianceaid.com for specific info on this. Best to remove the tranny and tub as a unit to replace the tub seal/bearing. Biggest problem with these is getting the tub nut off, they tend to freeze up.
__________________
- Last edited by richappy : 12-19-2008 at 03:34 AM. |
| Display Modes | |
| washer tub seal replacement? | patricia langston | Washer Repair | 1 | 01-28-2010 06:08 AM |
| Maytag Washer Tub Seal and Bearing Replacement | Paully | Washer Repair | 1 | 01-09-2010 03:49 AM |
| Whirlpool washer thrust seal replacement behind coupler | Greg1234 | Washer Repair | 3 | 11-11-2009 06:22 PM |
| GE Spacemaker XL Stirrer Motor replacement | Ann Futrell | Microwave Repair | 0 | 07-11-2009 06:11 AM |
| GHW9300PW - Whirlpool duet washer - Front tub seal, bellow replacement | jingi1234 | Washer Repair | 0 | 04-01-2009 06:36 AM |
