My maytag washer will not drain. It goes through the whole timer cycle,fills, agitates,won't drain and spins. I pulled the front cover off and watched it go through its cycles, put nothing happens when it gets to the drain cycle. The water will not drain during the spin cycle.
Hi David, Perform the troubleshooting as described in the Service manual (page 4-10) and post the results. Here are the break down diagrams for the Maytag washer Model LAT9604AAEGene.
Gene, Thanks for your fast response.
As I was about to reinstall the water pump, I found that the impeller of the pump was just spinning on the shaft. So I am going to order a new water pump, and things should be good. If for some reason this don't work I'll talk to you soon.
Thanks again.
