I Bought A New Pump For This And Water Still Will Not Pump Out And Go To Rinse, A Few Times When I Tried Water Came Runnin Out From The Bottom So Its Not The Pump Please Help, The Dryer That Goes With This Set Is Acting Up Also,, It Tries To Come On But The Drum Wont Go And Heat Wont Come On Ughhhhh Please Help
You need to operate it with the cabinet off (bypass the lid switch) so you can see how and why water is coming out. Also, you need to check for something plugging the drain hoses from the tub. Finally, I would take off the pump and see if you can put it in spin mode, in which case if the motor will turn the problem is with the pump or lines.
