| » washer shaking violantly. |
Model Number: MHWZ600TW Brand: Maytag Age: 1 - 5 years
shakes violatnly.. no matter what the load.. if i try to hold it down it stops and doesn't shake as much.. but i can't do that each time of cours.e
don't know what to do ? really really shakes.... leveled the feet and all. surface is flat and on tile cement floor. i think it's something else. will this be hard to replace the part that it needs.. please let me know.. if you could call me that's even better. i can be reached on my cell 203-258-5125. thanks ! kathleene Ads By Google Related Models |
Quote:
Kathlene, Here's something you can try, Open the door and see if the inner tub is centerred in the opening(empty). See if you can move the tub assembly around in various directions, and see if it sticks in one area. Is your washer mounted on a pedestal ?(there will be a slight increase in vibration if it is). Raise the two front lavelling legs(one at a time) and slip a playing card underneath the feet and turn them back down, put the washer into a spin cycle, let it get to the highest spin speed, and adjust the legs/feet until the cards cannot be pulled out from under the feet, and the vibration is gone. Then, put the washer into another spin cycle, when it reaches the high spin speed, stand 10 -12 inches away from the front, can you feel excessive vibration in the floor ? if yes, you have a weak floor, if no we'll have to dismantle the machine and start checking the suspension system for worn, damaged, weak parts. We'll keep an eye out for your response.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| washer started shaking when in spin, bad | roneq | Washer Repair | 0 | 11-13-2010 11:53 AM |
| washer shaking while spinning | anneanne | Washer Repair | 1 | 10-12-2010 12:17 PM |
| Washer Shaking | 5under5 | Washer Repair | 0 | 05-02-2010 06:43 AM |
| Maytag Washer severely shaking | 1jack | Washer Repair | 1 | 12-23-2009 01:26 PM |
| bosch washer spinnig and shaking | dmackool | Washer Repair | 0 | 01-03-2009 12:54 PM |
