Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer want spin (http://forum.appliancepartspros.com/washer-repair/173932-washer-want-spin.html)
henrylunsford 02-16-2011 12:06 PM
washer want spin
washer is not spining its making ahumming sound when its suppose 2 b spining
Gene 02-16-2011 02:07 PM
Open the control panel and check the relay board (#17 on the diagram) for a burned spots and/or cold solder joints.
- The relay board Part number: AP3097916
Joe / APP Team 02-16-2011 02:32 PM
Quote:
Henry,
A couple of easy, mechanical checks you probably should make, before we go too far,
Does the washer fill and wash and drain ?
We can almost eliminate the lower components (motor, pump, and coupler) and concentrate on the control,or relay board first, if it does.
Part number: 3407147R
Part number: 3407099R
Do you have a multi meter so we can check circuits ?
Part number: AP3873826
We'll keep an eye out for your response,
:cool: :cool: :cool:
