my matag brovos goes in to lb erra looked and wont let it run,:mad: in hand book showing door lach mite be the problem can you help me .tried pulling plug for a minnet no luck .
Originally Posted by: anthony rizzolo my matag brovos goes in to lb erra looked and wont let it run,:mad: in hand book showing door lach mite be the problem can you help me .tried pulling plug for a minnet no luck . Anthony, Hopefully you have a sticky lid lock assembly, or loose connection on the harness. But here is a copy of the Technical Data sheet, so you can run the board output tests and diagnostic tests, and we can have a better idea of where the problem is. Good Luck, :) :) :)
