Discuss
Noisy Clutch Assy
 in
Washer Repair
I purchased a new clutch assy and while assembling the unit back I forgot how the thrust washer goes on.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noisy Clutch Assy
  #1 (permalink)
Old 02-15-2011, 06:27 PM
Junior Member
kissdude is on a distinguished road
Default Noisy Clutch Assy
Model Number: LSQ9264HQ0   Brand: Whirlpool   Age: 5 - 10 years
I purchased a new clutch assy and while assembling the unit back I forgot how the thrust washer goes on. Should the cup face up or down?
Related Models
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
  #2 (permalink)
Old 02-16-2011, 04:35 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I assume you are talking about the plastic cam, that releases the brake, (the thrust washer is a part on a Maytag). It goes with the "finger" in the down position.
__________________
  #3 (permalink)
Old 02-16-2011, 05:46 PM
Junior Member
Default
Quote:
No I have a whirlpool and it has a metal thrust washer. I have it in the down position but I believe the transmission is the part that is actually bad. I can hold the rod while the machine is in the spin mode or the wash mode. So I guess the gears are stripped inside.
  #4 (permalink)
Old 02-17-2011, 02:55 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
There is a bottom tab on the thrust washer, must be seated in a slot in the tranny. If you suspect a bad tranny, turn the tranny coupler clockwise till the clutch housing starts to turn, any "roughness" while turning confirms a bad tranny nylon gear. Turning it clockwise and the agitator should go back and forth.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clutch or no Clutch on the timer? TimN Dryer Repair 2 02-19-2010 09:28 AM
atch assy janmax731 Dishwasher Repair 2 11-20-2009 12:25 PM
trans assy acianciull Washer Repair 1 03-07-2009 08:36 AM
Rod & Spring Assy ? gilkelley Washer Repair 1 02-03-2009 07:03 PM
Agitator Assy John MAC Washer Repair 0 02-14-2008 08:27 AM
