Discuss
Washer Completes Cycle, then won't fill
 in
Washer Repair
I have a whirlpool top loading washer that is having a weird issue. I am able to use 1 complete
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Completes Cycle, then won't fill
  #1 (permalink)
Old 12-15-2008, 07:57 AM
Junior Member
jsthomas75 is on a distinguished road
Default Washer Completes Cycle, then won't fill
Model Number: LSR8233JQ0   Brand: Whirlpool   Age: 5 - 10 years
I have a whirlpool top loading washer that is having a weird issue. I am able to use 1 complete cycle, but if I try to do another load of laundry, the washer goes right into the wash cycle without filling. If I let it sit overnight, the next morning I can do a load, but then the same issue exists. Does anyone have any experience with this problem? It makes no difference which wash cycle, water level, or heat level I use, I get the same result.
Any help would be greatly appreciated!
Thank you
Ads By Google
Related Models
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
Whirlpool LSV7233BN0
Whirlpool LSV7233BQ0
Whirlpool LSV7233BW0
Whirlpool LSV7233DQ0
  #2 (permalink)
Old 12-15-2008, 10:26 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
No experience with this particular problem but can give you a couple possible causes.
The switch inside the water level switch/diaphragm may be sticking.
You may have crud in the pressure tube that goes down into the wash tub.
I would lean towards the first one.
Run a load, remove the tube from the switch if it fills then the tube has a blockage.
Could try just blowing into the tube
If it does not fill then odds are the switch is no good.
Give it a tap now if it fills, it is the switch.
__________________
  #3 (permalink)
Old 12-15-2008, 11:07 AM
Junior Member
Default
Denman,
Thanks for the post. When I get home this evening I will check the pressure tube and try what you suggest. I can tell you I recently had to change the lid switch on this washer, and it is possible I pinched the hose when I reassembled the unit. I will let you know what happens.
Thanks again!!!
  #4 (permalink)
Old 12-18-2008, 05:14 AM
Junior Member
Default
Ok, I have pulled the washer apart and there was no blockage on the tube. I pulled it off both the washer bin as well as the level switch, blew in it and it was clear as a whistle. I put everything back together and it worked perfectly for 2 days and then went right back to it's old ways. At this point I assume it is the switch. I am going to order a replacement and hopefully that will fix it.
Thanks,
Justin
  #5 (permalink)
Old 12-18-2008, 05:53 AM
Senior Expert
APP Volunteer
Default
Yes that is also what I would do.
Sometimes you just touch a part and it starts working so you have you to make an educated guess and try a new part.
__________________
  #6 (permalink)
Old 12-18-2008, 06:51 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Replace the water level switch. It is the only thing, that could make the washer agitate with no water. Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wASHER CONTINUES TO FILL THROUGHOUT CYCLE armyguber Washer Repair 1 08-06-2009 03:26 PM
Maytag washer completes delicate cycle only WSR Washer Repair 1 05-12-2009 01:36 PM
Maytag Dryer completes cycle fast givemefood Dryer Repair 6 12-10-2008 07:04 PM
Maytag washer completes delicate cycle only. rsimms Washer Repair 8 11-22-2008 12:36 PM
Washer tub fills with water after the spin cycle completes vinnyvmj Washer Repair 0 02-17-2008 09:09 AM
