Tughill
#1 Posted : Tuesday, February 15, 2011 11:26:54 AM(UTC)
Tughill
Quit Running while on spin cycle. Wife put it to extra rinse cycle and began to fill again,it quit filling. Have tried all cycles, nothing now works. Power OK, Fuse OK, It will fill if I short the wires together at control for water level. No power at motor. Thanks
#2 Posted : Tuesday, February 15, 2011 1:13:30 PM(UTC)
Locate the water level switch (#21 on the diagram).
Note how the wires are connected to the terminals. Remove the wires and check for continuity across the terminals #7 & #6 while the washer is full of water.
If there is no continuity, check the air pressure hose by disconnecting it from the water level switch and blowing some air through it.
If the hose is clear then the water level switch has gone bad. Unfortunately this part has been discontinued by the manufacturer.
Here are the breakdown diagrams and Replacement parts for MAYTAG LAT8804AAE WASHER-TOP LOADING | AppliancePartsPros.com
Kitchenaid quits mid cycle, goes to cancel/drain (Dishwasher Repair)
by T_mich 2/4/2024 11:11:49 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
KENMORE REFRIG LIGHTS ALL QUIT W0RKING (Refrigerator & Freezer Repair)
by Guest 4/20/2022 11:20:29 AM(UTC)
GE washer just quit (Washer Repair)
by patrick2231 8/1/2021 11:15:14 AM(UTC)
Whirlpool top load washer Model # WTW58ESVW quit working (Washer Repair)
by chuck gibson 3/12/2021 4:37:30 PM(UTC)
2014 Kenmore Washer starts to agitate then quits? (Washer Repair)
by jpickar 1/25/2020 2:59:17 PM(UTC)
Summit Freezer quit working (Refrigerator & Freezer Repair)
by TheBishop 7/30/2018 7:18:00 PM(UTC)
GE dryer runs 20 seconds then quits smell burning (Dryer Repair)
by Ritawashere@gmail.com 8/25/2017 3:08:03 AM(UTC)
Kenmore washer lound noise and quit (Washer Repair)
by Machspeed 6/2/2017 7:47:03 PM(UTC)
Dryer Quits (Dryer Repair)
by usmc2033 3/6/2017 12:12:38 PM(UTC)
Whirlpool freezer quit again (Refrigerator & Freezer Repair)
by atonguis 1/28/2017 2:45:53 PM(UTC)
Freezer not quite cold enough (Refrigerator & Freezer Repair)
by sraykens 1/2/2017 8:25:10 AM(UTC)
microwave quit (Microwave Repair)
by mkydink 8/21/2016 7:22:20 AM(UTC)
Freezer tries to kick in then quits. (Refrigerator & Freezer Repair)
by Reddragon510 4/20/2016 5:27:00 PM(UTC)
Washer quits then starts back after 20mins (Washer Repair)
by dcroom 4/16/2016 11:15:00 AM(UTC)
