Washer willl fill and wash but doesn't drain water and also doesn't seem to run thru spin cycle. Will slosh back and forth but doesn't spin enough to get water to drain off washed clothes
Originally Posted by: dwarne Washer willl fill and wash but doesn't drain water and also doesn't seem to run thru spin cycle. Will slosh back and forth but doesn't spin enough to get water to drain off washed clothes need to know if it could be more than pump, perhaps the timer
