This Machine Fills With Water Agitates Fine Drains Fine But As Soon As It Tryes To Spin Its Shuts Off In About 3 Seconds. Spins Fine With No Clothes In It. Is The Moter Heating Up An Tripping Some Kind Of Thermal Switch? Any Help Would Be App.
Well since it spins without clothese in it, that suggest there is no problem with the electrical components. Sounds like either the transmission is the problem and that it will not handle a load, which is causing the motor's thermal protection device to shut it off, or the motor is failing or the clutch is going bad.
These parts are expensive so think about whether or not you want to fix or replace.
