JMS1953
#1 Posted : Sunday, December 14, 2008 4:15:43 PM(UTC)
JMS1953
Washer Will Agitate & Pump Water Out
But Spins Only About 10 Seconds, In
Any Cycle-wash-rinse-delecate
#2 Posted : Monday, December 15, 2008 7:42:54 PM(UTC)
Originally Posted by: JMS1953 Go to Quoted Post
...But Spins Only About 10 Seconds...
Does the motor stop? If it does then remove the front panel and check if the motor is hot at this time. Post the results.
Here are the break down diagrams for the GE washer Model WBSR1060T2AA
JMS1953
#3 Posted : Tuesday, December 16, 2008 5:34:28 PM(UTC)
JMS1953
Checked Motor.very Hot To The Touch!!!
JMS1953
#4 Posted : Tuesday, December 16, 2008 5:36:20 PM(UTC)
JMS1953
#5 Posted : Tuesday, December 16, 2008 8:40:56 PM(UTC)
Remove the belt and move the transmission pulley manually. If it moves in both ways then the motor is bad and has to be replaced.
Samsung Dryer Spinning Problem (Dryer Repair)
by pjenkins5212 3/31/2020 11:49:07 AM(UTC)
Maytag Bravos agitation and spinning problem (Washer Repair)
by rosocarne 5/1/2016 9:34:54 AM(UTC)
Kenmore 80 series washer spinning problems (Washer Repair)
by dw17dw17 2/11/2014 9:53:23 AM(UTC)
Whirlpool Washer spinning problem (Washer Repair)
by KSS 1/26/2013 9:39:50 PM(UTC)
GE Top Load washer agitating & spinning problems (Washer Repair)
by chedrick 11/9/2012 6:13:51 PM(UTC)
Whirlpool washer spinning problem (Washer Repair)
by Bob1958 10/21/2012 7:10:26 AM(UTC)
Spinning Problems (Washer Repair)
by gate1 1/28/2012 12:26:56 PM(UTC)
Spinning problem (Washer Repair)
by RC Cola 7/9/2011 7:09:16 AM(UTC)
Whirlpool front loading washer spinning problems (Washer Repair)
by godp1301 2/22/2010 7:00:10 AM(UTC)
Amana washer Bearing and Spinning problem (Washer Repair)
by papabear1245 5/30/2009 2:35:35 PM(UTC)
