Can you tell me what the brake cam posistion is? Does it slide into the spring steel dog leg that holds the blue spring, or does it just float inside loose?
On this model the brake cam will float loose. Do not put it between the metal legs where the spring is.
Originally Posted by: Jeff / APP Team On this model the brake cam will float loose. Do not put it between the metal legs where the spring is. Jeff you are awsome. You have absolutley made my day with your quick response and PRO knowledge. I want to thank you for all your help. I will send anyone who needs help and hopefully they will be just as satisfied. Again, THANK YOU my friend! From a very satisfied customer. God bless!!!!!:) :) :) :) :)
