Discuss
white westinghouse 2 speed
 in
Washer Repair
My white westubghouse will fill then you hear a click then all it does is hum. After what is supposed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » white westinghouse 2 speed
  #1 (permalink)
Old 12-14-2008, 08:02 AM
washing momma blues washing momma blues is offline
Junior Member
washing momma blues is on a distinguished road
Default white westinghouse 2 speed
Model Number: MWX413REW1   Brand: White-Westinghouse   Age: 5 - 10 years
My white westubghouse will fill then you hear a click then all it does is hum. After what is supposed to be the washcycle then it sounds like it spins out then rinse fill then it sounds like it spins out again. When you lift the lib to see what is done and the autolock from the lib will let you open there is no water and the clothes are still a little wet not so much on the top but as you go down futher the wetter they get. Can you help a women on her own trying to fix it. Thank you. washing momma blues
Related Models
Frigidaire MWX413REW1 Frg(v0) / Washer
Frigidaire MWX433RED0 Frg(v1) / Washer
Frigidaire MWX433RED1 Frg(v1) / Washer
Frigidaire MWX433RED2 Frg(v1) / Washer
Frigidaire MWX433RED3 Frg(v1) / Washer
Frigidaire MWX433REW0 Frg(v2) / Washer
Frigidaire MWX433REW1 Frg(v2) / Washer
Frigidaire MWX433REW2 Frg(v2) / Washer
Frigidaire MWX433REW3 Frg(v2) / Washer
Frigidaire MWX445MBD0 Frg(v3) / 27 " Washer
Frigidaire MWX445MBD2 Frg(v1) / Washer
Frigidaire MWX445MBD3 Frg(v2) / Washer
Frigidaire MWX445MBD4 Frg(v1) / Washer
Frigidaire MWX445MBW0 Tap(v7) / 27 " Washer
Frigidaire MWX445MBW1 Frg/27" Washer
Frigidaire MWX445MBW2 Frg(v3) / Washer
Frigidaire MWX445MBW3 Frg(v4) / Washer
Frigidaire MWX445MBW4 Frg(v2) / Washer
Frigidaire MWX445MBWD0 Gib(v10) / 27 " Washer
Frigidaire MWX445MBWL0 Frg(v2) / 27 " Washer
Frigidaire MWX445MBWO Frg(v1) / 27 " Washer
Frigidaire MWX445MBWW0 Frg(v1) / 27 " Washer
Frigidaire MWX445RBD0 Frg(v4) / 27 " Washer
Frigidaire MWX445RBD2 Frg(v5) / Washer
Frigidaire MWX445RBD4 Frg(v3) / Washer
Frigidaire MWX445RBW0 Tap(v8) / 27 " Washer
Frigidaire MWX445RBW1 Frg/27" Washer
Frigidaire MWX445RBW2 Frg(v6) / Washer
Frigidaire MWX445RBW3 Frg(v5) / Washer
Frigidaire MWX445RBW4 Frg(v4) / Washer
Frigidaire MWX445RBWD0 Gib(v12) / 27 " Washer
Frigidaire MWX445RBWL0 Frg(v4) / 27 " Washer
Frigidaire MWX445RBWW0 Gib(v11) / 27 " Washer
Frigidaire MWX645RES0 Frg(v1) / Washer
Frigidaire MWX645RES1 Frg(v0) / Washer
Frigidaire MWX645RES2 Frg(v0) / Washer
Frigidaire MWX645RES3 Frg(v0) / Washer
Frigidaire MWX645RES4 Frg(v0) / Washer
Frigidaire MWX645RET0 Frg(v2) / Washer
Amana MX1550.000 Commercial Microwaves
International MX400 Ref - Top Mount
Maytag MX410 Ref - Sxs
Maytag MX411 Ref - SXS/I&W
Frigidaire MXLG62RBD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MXLG62RBW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MXW121RBW0-23 Tap(v8) / 27 " Washer
International MYE3350AGW Washer - Top Loading
International MZ2727EEGB Ref - SXS/I&W
International MZ2727EEGW Ref - SXS/I&W
Maytag MZD2663KEB Ref - SXS/I&W
Maytag MZD2663KEQ Ref - SXS/I&W
Maytag MZD2663KES Ref - SXS/I&W
Maytag MZD2663KEW Ref - SXS/I&W
Maytag MZD2665HEB Ref - SXS/I&W
Maytag MZD2665HEQ Ref - SXS/I&W
Maytag MZD2665HES Ref - SXS/I&W
Maytag MZD2665HEW Ref - SXS/I&W
Maytag MZD2666KEB Ref - SXS/I&W
Maytag MZD2666KES Ref - SXS/I&W
Maytag MZD2666KEW Ref - SXS/I&W
Maytag MZD2667HEB Ref - SXS/I&W
Maytag MZD2667HEQ Ref - SXS/I&W
Maytag MZD2667HES Ref - SXS/I&W
Maytag MZD2667HEW Ref - SXS/I&W
Maytag MZD2669KEB Ref - SXS/I&W
Maytag MZD2669KEQ Ref - SXS/I&W
Maytag MZD2669KES Ref - SXS/I&W
Maytag MZD2669KEW Ref - SXS/I&W
Maytag MZD2752GRB Ref - SXS/I&W
Maytag MZD2752GRQ Ref - SXS/I&W
Maytag MZD2752GRS Ref - SXS/I&W
Maytag MZD2752GRW Ref - SXS/I&W
Maytag MZD2766GEB Ref - SXS/I&W
Maytag MZD2766GEQ Ref - SXS/I&W
Maytag MZD2766GES Ref - SXS/I&W
Maytag MZD2766GEW Ref - SXS/I&W
Maytag MZD2768GEB Ref - SXS/I&W
Maytag MZD2768GEQ Ref - SXS/I&W
Maytag MZD2768GEW Ref - SXS/I&W
Norge N1100PAW Range - F/s Std Gas
Norge N1100PRA Range - F/s Std Gas
Norge N1100PRA-L Range - F/s Cont Clean Gas
Norge N1100PRW Range - F/s Std Gas
Norge N1100PRW-L Range - F/s Cont Clean Gas
Norge N1500PRA Range - F/s Std Ele
Norge N1500PRW Range - F/s Std Ele
Norge N31100PAA Range - F/s Std Gas
Norge N31100PAW Range - F/s Std Gas
Norge N3110KRA Range - F/s Std Gas
Norge N3110KRW Range - F/s Std Gas
Norge N3110PPA Range - F/s Std Gas
Norge N3110PPW Range - F/s Std Gas
Norge N3110PRA Range - F/s Std Gas
Norge N3110PRW Range - F/s Std Gas
Norge N31111XAA Range - F/s Std Gas
Norge N31111XAW Range - F/s Std Gas
Norge N31115WAV Range - F/s Std Gas
Norge N31115XAA Range - F/s Std Gas
Norge N31115XAW Range - F/s Std Gas
Norge N3120SPA Range - F/s Std Gas
Norge N3120SPN Range - F/s Std Gas
Norge N3120SPW Range - F/s Std Gas
Norge N3120SRA Range - F/s Std Gas
Norge N3120SRW Range - F/s Std Gas
Norge N3121XPA Range - F/s Std Gas
Norge N3121XPW Range - F/s Std Gas
Norge N3121XRA Range - F/s Std Gas
Norge N3121XRW Range - F/s Std Gas
Norge N3121XTA Range - F/s Std Gas
Norge N3121XTW Range - F/s Std Gas
Norge N3137XRA Range - F/s Std Gas
Norge N3137XRW Range - F/s Std Gas
Norge N3137XUA Range - F/s Std Gas
Norge N3137XUW Range - F/s Std Gas
Whirlpool N3157W0
Whirlpool N3157W1
Whirlpool N3157^0
Whirlpool N3157^1
Norge N3177VUV Range - F/s Std Gas
Norge N3177XRA Range - F/s Std Gas
  #2 (permalink)
Old 12-15-2008, 05:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
If you know how to use a simple tools then you probably can do it.
Remove the front panel and check the belt. Remove the belt and run the washer to see if the motor works. Post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
White Westinghouse Spacemate dorothea Washer Repair 8 09-13-2009 09:06 PM
White Westinghouse Spacemate dorothea Washer Repair 0 09-05-2009 12:44 PM
White Westinghouse Thermostat replacement kvs2000 Oven Repair (including Ranges and Cooktops) 0 04-30-2009 03:02 PM
Please Help.....White Westinghouse Spacemates oceanmaid Dryer Repair 1 09-05-2008 04:16 PM
white-westinghouse dishwasher. mommieof2 Dishwasher Repair 1 09-19-2007 06:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
