Will not wash will lets in water, door lock latches but has a loud humming sound,Timer does not advance, pulled board out an fuse is blown. Does this mean it is the board that needs replaced?
Well Frigidaire says to replace both the motor and the speed control board, which to me sorta defeats the purpose of having a fuse in the first place.
Look inside the lower part of the machine with the panel off and see if you can find some tech notes. They will probably say the same thing.
