| » Loud knocking noise when washer is agitating mode |
Model Number: EWA560061WW Brand: GE Age: 1 - 5 years
My washer makes a loud knocking noise when in the agitating mode. Spin and drain cycle are OK. I have replaced the belt twice due to squeeking in agitating mode only. Anyone know what I should be looking for? I have checked the level and it is perfect.
There are two things that commonly cause this washer to be noisy.
One is that the sifter coil has failed. The sifter is what amounts to a large solenoid that engages or should I say disengages a gear. When the sifter coil is activated it disengages a gear that allows the agitator to move separately from the spin basket. When the sifter coil is not activated the agitator and the spin basket will be locked together. When the sifter fails the spin basket will turn during agitation mode. When this happens you will hear a knocking noise each time the motor changes directions because the brackets will hit from the force of a full tub of water rotating back and forth. The other is the sagging apron issue. This will typically cause a squealing noise. These two problems often go hand and hand because when the sifter fails there is a tremendous amount of stress put on the machine. Don’t get me wrong the sagging apron issue on some models will happen no matter what due to a manufacture defect but the sifter problem will make this a problem sooner rather than later. To see if you have the sagging apron issue set the washer to full water level, remove the front of the washer and start a cycle. Once agitation starts look under the motor and see if the motor bracket is hitting the bottom of the washer causing a squealing noise. This page talks about the sagging apron issue and also how to test the sifter coil GE HydroWave Noisy Washer Repair Guide |
I have read a reply about a sifter coil casusing a knocking noise only during agitation. My washer is a whrilpool Model LSQ9210HQ0. I can not find anything called a sifter coil. Can someone send me the information on this sifter coil?
Thanks, Dennis |
| Display Modes | |
| Washer making noise both agitating ansd spinning | NANCY101 | Washer Repair | 3 | 08-25-2010 09:42 AM |
| My washer makes shrill noise when agitating | joeboo04 | Washer Repair | 1 | 10-19-2009 10:06 AM |
| washer drum makes knocking noise | pgm9057 | Washer Repair | 10 | 07-20-2009 11:46 AM |
| Loud rubbing noise in spin mode | seeyoujimmy | Washer Repair | 3 | 03-28-2009 02:04 PM |
| Washer Noise - Not Agitating | brittdavekota | Washer Repair | 0 | 08-27-2007 08:28 AM |
