Discuss
Whirlpool Duet Parts
 in
Washer Repair
MCU part # 8182706 Part Details - WHIRLPOOL Motor control unit, part number: 8182706
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Parts
  #11 (permalink)
Old 10-25-2008, 10:08 AM
RegUS_PatOff RegUS_PatOff is offline
Member
RegUS_PatOff is on a distinguished road
Default
MCU part # 8182706
  #12 (permalink)
Old 12-22-2008, 04:00 PM
frank sartuche frank sartuche is offline
Junior Member
frank sartuche is on a distinguished road
Default Controler Locked
whirlpool duet #GHW925OML2. washer tells me controler is locked. how could I fix this problem
  #13 (permalink)
Old 12-22-2008, 04:53 PM
Member
Default
from the GHW9250ML2 Owner's Manual:
to LOCK or UNLOCK the Controls:
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED status light turns ON or OFF.
  #14 (permalink)
Old 12-23-2008, 09:13 AM
Docginnik365 Docginnik365 is offline
Junior Member
Docginnik365 is on a distinguished road
Default
Did you replace the front bellow? How hard was it to do yourself or did you have to have a repairman do it? Mine just went after 12 years and I have to replace it, and I don't know if I should attempt it or have a repairman man do it.
  #15 (permalink)
Old 04-14-2009, 01:28 PM
frostywashdry frostywashdry is offline
Member
frostywashdry is on a distinguished road
Default
I just ordered a drain pump assembly today. I hope this solves the finicky drain. Some cycles it's fine, some cycles it F2's or SUD even with only 2 tablespoons HE liquid detergent. Most cycles it won't drain during the rinse cycle. I have taken apart the drain assembly cleaned it out, de junked it. Ran hot cycles etc...ugh.
I sure hope all this getting to know my washer today pays off when I install this new pump.
I feel empowered. 37 yr old Mother of 4. I did it!
While I was at it I took apart, front and back, my matching duet dryer and cleaned the whole inside. I even took off the lint catcher and vac'd it all out nice and purty. Holy coin-ville! About 3 pockets worth of change in the bottom og my dryer, lol!
  #16 (permalink)
Old 04-14-2009, 01:31 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
lol Good job!
Let us know how it works out.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #17 (permalink)
Old 04-14-2009, 01:36 PM
Member
Default
Thanks to your speedy shipping I should have it pretty quick and I'll be sure to let you know!
I've waited several months to decide to get the new pump. I've had issues for about 6 months and I've cleaned the drain 2 other times. (after coming here and getting directions on how to access the pump, wink) Do you think I was wise to start with replacing the pump?
  #18 (permalink)
Old 04-14-2009, 06:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by frostywashdry View Post
...Do you think I was wise to start with replacing the pump?...
This part is not too difficult to replace yourself. You can find the complete instructions in the Service manual.
__________________
  #19 (permalink)
Old 04-14-2009, 07:18 PM
Member
Default
I agree, I've already removed it 3 times over the last 6 months to clean it out. It was never bad. I think just having a family of 6 and Mt. Fuji in laundry has made my 6 yr old washer say enough, I need a new one.
Starting to have dryer issues too. I'm thinking sensor or heat coil but it's very hot, and I've already cleaned the sucker out so well it's sparkles inside and out. Just seems to take 2 cycles to dry on high heat, most dry. I've even played around with cycles to see if it was just the one cycle I use and nope.
Thanks for the Handy link Gene!!!!!!I saved that to favorites!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer parts Admin / APP Team Washer Repair 3 04-25-2009 08:32 AM
Dryer Parts Admin / APP Team Dryer Repair 11 09-10-2008 05:20 PM
whirlpool duet washer donnie Washer Repair 4 12-31-2007 05:41 AM
Whirlpool Duet Washer Loud Spin Reb Washer Repair 0 09-30-2007 11:43 AM
whirlpool duet frontloader puet color desertsilk Washer Repair 0 07-24-2007 08:25 PM
