Washing machine leaking
Our washing machine is leaking water on the floor. It seems to be coming from the center of the machine. Do you have any suggestions, manuals, or tech sheets? Any help would be greatly appreciated. |
Check the pump. Here's a video that will elp you access it.
YouTube - WHIRLPOOL WASHER REPAIR VIDEO 1 |
any printouts?
Quote:
washing machine leak
Okay, after breaking down the diagram, we found there is a 1-1/2" crack in the outer drum. Do you know if we can epoxy this, or do we have to purchase a new drum?
I would try to epoxy the tub first. You can replace it, but if the epoxy holds, it may buy you some time.
leaky washer
Thanks, I appreciate all your help! Especially because the machine is only 3 years old. I can't imagine how the tub got a crack in it. ???
If you have the original paperwork, you may want to check to see if the tub is still under warranty.
leaking washer
Quote:
Just called Whirlpool. they said it was only covered for 1 year. Don't understand how that can break. Never buying Whirlpool again! |
Washer repair successful, but now...
Quote:
| All times are GMT -7. The time now is 01:54 AM. |
