| » Remove outer tub from basket on Maytag 3000 |
Model Number: MHWE300VF00 Brand: Maytag Age: 1 - 5 years
I'm trying to replace the outer tub on a Maytag 3000 front-load washer (MHWE300VF00), but I can't get the basket to separate from the outer tub. Can someone please tell me how to separate the outer tub from the basket?
Thank you! Ads By Google Related Models |
Hello,
If you have the tubs split and the inner tub will not pull free from the bearing you may want to try a rubber mallet and block of wood. Set the piece of wood on the top of the spin basket shaft, give it a tap and tub should pull free. Appliance Repair Technician: |
Thank you for replying. I already tried to knock it out as you suggested. I started out tapping it gently and worked my way up to hitting it so hard that I split several 2x4s. It won't budge.
Is there nothing that holds it in? |
| Display Modes | |
| how do you remove the basket from my washer | tlyons | Washer Repair | 2 | 09-14-2010 04:13 AM |
| Inner Basket Melted from Friction Against Outer Tub | Drayno | Washer Repair | 2 | 05-05-2009 05:02 PM |
| Maytag Neptune Mah 3000 Fuse | FATSO | Washer Repair | 1 | 02-10-2009 07:36 PM |
| How to remove basket | lbrock | Washer Repair | 1 | 10-02-2007 03:04 AM |
| How to remove spin basket nut | richappy | Washer Repair | 0 | 10-01-2007 04:19 AM |
