Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Remove outer tub from basket on Maytag 3000 (http://forum.appliancepartspros.com/washer-repair/171336-remove-outer-tub-basket-maytag-3000-a.html)
sehanks 02-10-2011 09:46 AM
I'm trying to replace the outer tub on a Maytag 3000 front-load washer (MHWE300VF00), but I can't get the basket to separate from the outer tub. Can someone please tell me how to separate the outer tub from the basket?
Thank you!
Repair Technician 02-10-2011 11:44 AM
Hello,
If you have the tubs split and the inner tub will not pull free from the bearing you may want to try a rubber mallet and block of wood.
Set the piece of wood on the top of the spin basket shaft, give it a tap and tub should pull free.
Appliance Repair Technician:
sehanks 02-10-2011 01:44 PM
Thank you for replying. I already tried to knock it out as you suggested. I started out tapping it gently and worked my way up to hitting it so hard that I split several 2x4s. It won't budge.
Is there nothing that holds it in?
