| » Fabric Softner Dispenser |
Quote:
Ashbaugh, In general, First, Check and make sure the washer is spinning at the proper speed. The dispenser works on centrifugal force, if the tub doesn't spin proper it won't dispense. The dispenser assembly,sort of "snaps" off the top of the agitator, it can be a bit tough, but not that bad. Take the assembly and put it in a container with hot(really hot) soapy(a lot of detergent) water and let it soak, 20 -30 minutes. You then need to check all the slots and openings on the bottom and the slots around the interior outside wall, use a small blade screwdriver and a scrub brush to clear any remaining residue and rinse the assembly off with hot water. You can also order a replacement dispenser if you wish, I could've given you the part numbers had you included a proper model number.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Fabric Softner not working | Twindad | Washer Repair | 11 | 08-30-2010 08:24 AM |
| Fabric Softner won't dispense | TexasBrat | Washer Repair | 1 | 03-30-2010 06:13 PM |
| Fabric softner Compartment | Watchmanwatchman4u55@yaho | Washer Repair | 1 | 02-28-2010 07:42 AM |
| Fabric Softner will not empty | EDT | Washer Repair | 0 | 04-08-2009 01:39 PM |
| Fabric Softner | zazagab | Washer Repair | 0 | 01-05-2008 11:23 AM |
