My Washer Makes A Grinding Noise After The Spin Cycle.i Need To Know If I Should Replace The Trunnion Or The Bearing. It Is Also Leaving A Lot Of Water In Dry Towels.
the trunion wouldn't cause it to make a grinding noiseunless its loose a spin bearing would be more of a squeal than a grind the gring could be coming from your drain pump
