i have a admiral washer machine we have had it for 3 yrs now we moved to tn 3 months ago from florida and have well water from a spring. the tubwill not fill water comes in but drains right out. what could this be and where could i find the part in washer so i can fix it. the washer worked perfectly fine when we were in florida. ty please help sirtaz78
Make sure your drain hose is above the top of the machine and the washer drain hose isn't down inside the pipe to far. This will cause a siphon effect.
nat
