My washer will fill with water and agitate for about 10 minutes. It then stops and goes into spin mode. then it rinses and spins again. I have replaced a broken belt and the timer. I checked the continuity of the lid switch and it's good. Any idea what the problem is ? Any help is appreciated.
Originally Posted by: fordguy65 My washer will fill with water and agitate for about 10 minutes. It then stops and goes into spin mode. then it rinses and spins again. I have replaced a broken belt and the timer. I checked the continuity of the lid switch and it's good. Any idea what the problem is ? Any help is appreciated. Fordguy, I must have missed something in your post, It sounds like it's working ? At least on a regular cycle, unless your complaint is, there is no drain ? (you didn't mention a drain cycle ). And a model number would be a great help. :confused: :confused: :confused:
