Discuss
Washer will run with no water in it
 in
Washer Repair
Hello, my washer does not fill up with water. Normally the wash cycle will need to fill the tub to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will run with no water in it
  #1 (permalink)
Old 02-07-2011, 02:26 PM
Junior Member
tony11 is on a distinguished road
Default Washer will run with no water in it
Model Number: AWM452W   Brand: Amana   Age: More than 10 years
Hello, my washer does not fill up with water. Normally the wash cycle will need to fill the tub to the selected water level before it will begin the wash cycle. Now it will begin agitating as soon as you turn on the wash cycle, like there is water in it. Water connections are good, no kinks/clogs, good water pressure from spigot. Any thoughts on this would be greatly appreciated. Thanks. Tony
Ads By Google
Related Models
Amana AWM472W Washer - Top Loading
Amana AWM472W2 Washer - Top Loading
Amana AWM473W Washer - Top Loading
Amana AWM473W2 Washer - Top Loading
Amana AWM492 Washer - Top Loading
Amana AWM493 Washer - Top Loading
Amana AWM531 Washer - Top Loading
Amana AWM551 Washer - Top Loading
Amana AWM572 Washer - Top Loading
Amana AWM573W Washer - Top Loading
Amana AWM573W2 Washer - Top Loading
Amana AWM592 Washer - Top Loading
Amana AWM593L Washer - Top Loading
Amana AWM593L2 Washer - Top Loading
Amana AWM593W Washer - Top Loading
Amana AWM593W2 Washer - Top Loading
Amana AWM631 Washer - Top Loading
Amana AWM651 Washer - Top Loading
Amana AWM692 Washer - Top Loading
Amana AWM693 Washer - Top Loading
Whirlpool AWMC6020
Whirlpool AWMC6320
Whirlpool AWMC7020
Whirlpool AWMC7021
Whirlpool AWMP4921
Whirlpool AWMP5021
Whirlpool AWMP5023
Whirlpool AWMP5123
Whirlpool AWMP5223
Whirlpool AWMP6022
Whirlpool AWMP6023
Whirlpool AWMP6123
Whirlpool AWMP6223
Whirlpool AWMP7020
Whirlpool AWMS6020
Whirlpool AWMS6021
Whirlpool AWMS8520
Whirlpool AWMS8521
Frigidaire AWP110S2W Kel(v3) / 24 " Washer
Frigidaire AWP220S2W Kel(v4) / 24 " Washer
Frigidaire AWP330A0D Kel(v4) / 24 " Washer
Frigidaire AWP330A0T Kel(v5) / 24 " Washer
Frigidaire AWP330A0W Kel(v6) / 24 " Washer
Frigidaire AWP330A1D Kel(v4) / 24 " Washer
Frigidaire AWP330A1T Kel(v5) / 24 " Washer
Frigidaire AWP330A1W Kel(v6) / 24 " Washer
Frigidaire AWP330F1D Kel(v2) / 24 " Washer
Frigidaire AWP330F1W Kel(v1) / 24 " Washer
Frigidaire AWP330F2D Kel(v2) / 24 " Washer
Frigidaire AWP330F2W Kel(v1) / 24 " Washer
Frigidaire AWP330G1D Kel(v2) / 24 " Washer
Frigidaire AWP330G1W Kel(v1) / 24 " Washer
Frigidaire AWP330H1L Kel(v2) / 24 " Washer
Frigidaire AWP330H1W Kel(v1) / 24 " Washer
Frigidaire AWP330H2D Kel(v2) / 24 " Washer
Frigidaire AWP330H2W Kel(v1) / 24 " Washer
Frigidaire AWP330H3D Kel(v2) / 24 " Washer
Frigidaire AWP330H3W Kel(v1) / 24 " Washer
Maytag AWS  Water Filtration System
Frigidaire AWS100C1D Kel(v1) / Tumble Action Washer
Frigidaire AWS100C1W Kel(v2) / Tumble Action Washer
Whirlpool AWW09040
Whirlpool AWW09041
Whirlpool AWW10540
Whirlpool AWW15040
Whirlpool AX5133VG0
Whirlpool AX5133VG1
Whirlpool AX5133VL0
Whirlpool AX5133VL1
Whirlpool AX5133VW0
Whirlpool AX5133VW1
Whirlpool AX6245VG0
Whirlpool AX6245VG1
Whirlpool AX6245VL0
Whirlpool AX6245VL1
Whirlpool AX6245VW0
Whirlpool AX6245VW1
Whirlpool AXBP4920
Whirlpool AXBP4921
Whirlpool AXC10020
Whirlpool AXC11021
Whirlpool AXC11022
Whirlpool AXC11023
Whirlpool AXC11024
Whirlpool AXC11025
Whirlpool AXC11540
Whirlpool AXC11541
Whirlpool AXC12040
Whirlpool AXC12041
Whirlpool AXC14041
Whirlpool AXC14543
Whirlpool AXC14544
Whirlpool AXC15040
Whirlpool AXC15041
Whirlpool AXCP8020
Whirlpool AXCP8021
Whirlpool AXE04920
Whirlpool AXE05920
Whirlpool AXE06020
Whirlpool AXE06021
Whirlpool AXE09030
Whirlpool AXE11540
Whirlpool AXE14540
Whirlpool AXE15040
Whirlpool AXE18030
Whirlpool AXF07520
Whirlpool AXF10020
Whirlpool AXF11020
Whirlpool AXF12540
Whirlpool AXF13020
Whirlpool AXF13021
Whirlpool AXF13022
Whirlpool AXF17040
Whirlpool AXF18530
Whirlpool AXF20040
  #2 (permalink)
Old 02-08-2011, 04:38 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for AWM452W models | AppliancePartsPros.com
Sounds like a water level switch problem.Item 15 in Section 10.
Could be that the switch contacts are welded shut so the unit thinks that it is full and therfore never fills.
The way it works is:
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge washer no water in tub gmsumm Oven Repair (including Ranges and Cooktops) 0 10-26-2010 03:20 PM
not enough water in washer camano Washer Repair 1 10-13-2010 09:49 AM
No hot water in washer gladys09 Washer Repair 1 02-21-2010 10:58 AM
GE washer does not have hot water danvolz Washer Repair 0 02-20-2009 12:47 PM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
