I Have Whirpool Washer Duet #ghw9150pwo. I Pushed Control On Button, No Lights Came On. Checked The Filter For Power Supply And Got 115 Volts Across The Terminals. Proceeded To Check All Connections To The Cpu And Other Terminals, Also Took Off Frount Control Panel Off And Check For Connections. Pushed The Control Button Again, Power And Leds Came On. I Did A Load And Ran A Full Cycle. It Shut Off And Again No Leds Would Come On After Holding Control On Button. It Seems I Have A Frayed Wire From The Control To Cpu, If So Were Does It Normally Fray. Is Their Problems With Control On Button Or Cpu. Please Advise, Thanks.
It is possible that you have a problem wire, and you will need a meter to check continuity and resistence of the wiring from the branch of the incoming power to the various components.
Based on your symptoms though, I would say it is more likely you have a problem with the switch that turns things on.
