Discuss
Washer will not spin after new clutch and nuetral drain assembly
 in
Washer Repair
Everything on my washer works EXCEPT spinning. I've replaced the clutch, which did not fix the problem, so I replaced
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not spin after new clutch and nuetral drain assembly
  #1 (permalink)
Old 02-06-2011, 11:48 AM
Junior Member
Spokey is on a distinguished road
Default Washer will not spin after new clutch and nuetral drain assembly
Model Number: KAWE560WWH3   Brand: Kitchen Aid   Age: More than 10 years
Everything on my washer works EXCEPT spinning. I've replaced the clutch, which did not fix the problem, so I replaced the nuetral drain assembly. During that I did find that there is a round metal stud that one of the pieces sits on (a pawl switch I think it was called) was broken. Putting in the new kit, however, did not fix the problem. Proping the washer up and running it through a cycle, I can see that the clutch moves back and forth during agitate, the motor reverses ad the pump spins pumping out the water, but then I would expect to see the clutch spin again during the spin cycle. It does not move. Pulling out the gearcase again, I can turn the transmission coupler by hand. In the counterclockwise direction, everything turns smoothly inside. When switching to clockwise, within the first few revolutions there is a hang up that I need to use some force to get past, then the coupler spins easily and all of the parts seems to be moving, but I do not always see the tub shaft turning.
First, can someone verify that I've put these parts in correctly?
I used the attachment feature to upload 3 pics, but don't see them anywhere. Please give me directions on how to supply a picture.
Second what else should I check?
Ads By Google
Related Models
Whirlpool KAWE560WWH3
Whirlpool KAWE564WAL0
Whirlpool KAWE564WAL1
Whirlpool KAWE564WAL2
Whirlpool KAWE564WAL3
Whirlpool KAWE564WWH0
Whirlpool KAWE564WWH1
Whirlpool KAWE564WWH2
Whirlpool KAWE564WWH3
Whirlpool KAWE565BWH0 AUTOMATIC WASHER
Whirlpool KAWE565BWH1 AUTOMATIC WASHER
Whirlpool KAWE567WWH0
Whirlpool KAWE570BWH0 AUTOMATIC WASHER
Whirlpool KAWE570BWH1 AUTOMATIC WASHER
Whirlpool KAWE577BWH0 AUTOMATIC WASHER
Whirlpool KAWE577BWH1 AUTOMATIC WASHER
Whirlpool KAWE578BAL0
Whirlpool KAWE578BAL1
Whirlpool KAWE650VAL0
Whirlpool KAWE650VWH0
Whirlpool KAWE660WAL0
Whirlpool KAWE660WAL1
Whirlpool KAWE660WAL2
Whirlpool KAWE660WAL3
Whirlpool KAWE660WWH0
Whirlpool KAWE660WWH1
Whirlpool KAWE660WWH2
Whirlpool KAWE660WWH3
Whirlpool KAWE665BWH0 AUTOMATIC WASHER
Whirlpool KAWE667BWH0
Whirlpool KAWE667BWH1 AUTOMATIC WASHER
Whirlpool KAWE668BAL0
Whirlpool KAWE668BAL1
Whirlpool KAWE670BAL0
Whirlpool KAWE670BWH0
Whirlpool KAWE670BWH1
Whirlpool KAWE677BWH0
Whirlpool KAWE677BWH1
Whirlpool KAWE678BAL0
Whirlpool KAWE678BAL1
Whirlpool KAWE679BBL0
Whirlpool KAWE679BBL1
Whirlpool KAWE700TWH0
Whirlpool KAWE742BAL0
Whirlpool KAWE742BWH0
Whirlpool KAWE742VAL0
Whirlpool KAWE742VWH0
Whirlpool KAWE742WAL0
Whirlpool KAWE742WAL1
Whirlpool KAWE742WAL2
Whirlpool KAWE742WAL3
Whirlpool KAWE742WWH0
Whirlpool KAWE742WWH1
Whirlpool KAWE742WWH2
Whirlpool KAWE742WWH3
Whirlpool KAWE750VAL0
Whirlpool KAWE750VWH0
Whirlpool KAWE755VAL0
Whirlpool KAWE755VWH0
Whirlpool KAWE760WAL0
Whirlpool KAWE760WAL1
Whirlpool KAWE760WAL2 AUTOMATIC WASHER
Whirlpool KAWE760WAL3 AUTOMATIC WASHER
Whirlpool KAWE760WWH0
Whirlpool KAWE760WWH1
Whirlpool KAWE760WWH2
Whirlpool KAWE760WWH3
Whirlpool KAWE764WAL0
Whirlpool KAWE764WAL1
Whirlpool KAWE764WAL2
Whirlpool KAWE764WWH0
Whirlpool KAWE764WWH1
Whirlpool KAWE764WWH2
Whirlpool KAWE767BWH0
Whirlpool KAWE767WAL0
Whirlpool KAWE767WWH0
Whirlpool KAWE768BAL0
Whirlpool KAWE768BAL1
Whirlpool KAWE768BWH0
Whirlpool KAWE770BAL0
Whirlpool KAWE770BWH0
Whirlpool KAWE770BWH1
Whirlpool KAWE777BWH0
Whirlpool KAWE777BWH1
Whirlpool KAWE778BAL0
Whirlpool KAWE778BAL1
Whirlpool KAWE800SWH1
Whirlpool KAWE800TWH0
Whirlpool KAWE842WAL0
Whirlpool KAWE842WAL1
Whirlpool KAWE842WAL2
Whirlpool KAWE842WWH0
Whirlpool KAWE842WWH1
Whirlpool KAWE842WWH2
Whirlpool KAWE850VAL0
Whirlpool KAWE850VAL1
Whirlpool KAWE850VWH0
Whirlpool KAWE850VWH1
Whirlpool KAWE860WAL0
Whirlpool KAWE860WAL1
Whirlpool KAWE860WAL2
Whirlpool KAWE860WAL3
Whirlpool KAWE860WWH0
Whirlpool KAWE860WWH1
Whirlpool KAWE860WWH2
Whirlpool KAWE860WWH3
Whirlpool KAWE870BAL0
Whirlpool KAWE870BWH0
Whirlpool KAWE870BWH1
Whirlpool KAWE877BWH1
Whirlpool KAWE878BAL1
Whirlpool KAWE900SWH1
Whirlpool KAWE900SWH2
Whirlpool KAWE900TWH0
Whirlpool KAWE900TWH1
Whirlpool KAWE950VAL0
Whirlpool KAWE950VWH0
Whirlpool KAWE960WAL0
Whirlpool KAWE960WAL1
Whirlpool KAWE960WWH0
  #2 (permalink)
Old 02-06-2011, 11:55 AM
Junior Member
Default pictures
might have figured out a way to view the pictures. Try these links...
The new neutral drain kit:
https://dkpllg.blu.livefilestore.com/y1p5MPLSCw_OFEmtRYak3KNWWO-zjv5ucXpbiABrdqjfk10qHtNU3ZDmMEw1PktfgHIBySpWY9NUO fTLGmy9e2ZQwirGs93q4CA/washer%20001.jpg?psid=1
and when I feel the resistence start:
https://dkpllg.blu.livefilestore.com...002.jpg?psid=1
  #3 (permalink)
Old 02-07-2011, 03:55 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Seems like a bad tranny. They are hard to fix, I would opt for a new one. AP3096209 Just checked and there is no one on this forum that has fixed one, but you could re-post and ask if anyone has fixed one.
__________________
  #4 (permalink)
Old 02-07-2011, 06:18 AM
Junior Member
Default Thanks
OK, thanks for the info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not spin after new clutch and nuetral drain assembly Spokey Washer Repair 0 02-06-2011 11:47 AM
Sears Washer - spin cycle clutch slip robd Washer Repair 2 10-05-2010 04:16 PM
Replaced clutch assembly; still won't spin jhillman Dishwasher Repair 1 07-28-2010 08:37 PM
whats the Job of the clutch assembly Gogetta Washer Repair 2 10-31-2008 01:59 AM
Washer won't spin...bad clutch? RobertC Washer Repair 6 07-11-2008 02:34 AM
