Discuss
front loading washer off balance in spin cycle
 in
Washer Repair
Something must have come loose, because the last time I used the washer, the spin cycle started and it sounded
Appliance Repair Forum > Appliance Repair Help > Washer Repair » front loading washer off balance in spin cycle
  #1 (permalink)
Old 12-09-2008, 10:20 PM
Junior Member
bruciemom is on a distinguished road
Default front loading washer off balance in spin cycle
Model Number: 417.29042991   Brand: Kenmore   Age: 5 - 10 years
Something must have come loose, because the last time I used the washer, the spin cycle started and it sounded like a giant had was crashing through my laundry room! This washer is sorta old but not *old* old and I'd like not to have to buy a new one. But it costs so much to have someone even come take a look at it - I need to know whether this is a minor vs. major repair so I can decide to fix or replace it. Thanks so very much for any help you can give.
Ads By Google
Related Models
Kenmore 417.29042991  KENMORE WASHER
Kenmore 417.29042992  FRONT LOAD WASHER
Kenmore 417.29052990  KENMORE WASHER
Kenmore 417.29052991  WASHER
Kenmore 417.39012890  STACK WASHER
Kenmore 417.39012891  WASHER
Kenmore 417.39022891  WASHER
Kenmore 417.40032990  WASHER
Kenmore 417.40042990  WASHER
Kenmore 417.40052990  WASHER
Kenmore 417.40142000  WASHER
Kenmore 417.41042000  WASHER
Kenmore 417.41052000  FRONTLOAD WASHER
Kenmore 417.41142000  RESIDENTIAL WASHER
Kenmore 417.42042100  WASHER
Kenmore 417.42052100  WASHER
Kenmore 417.42142100  WASHER
Kenmore 417.43042200  SEARS/FRONTLOAD WASHER
Kenmore 417.43052200  SEARS/FRONTLOAD WASHER
Kenmore 417.43142200  SEARS/FRONTLOAD WASHER
Kenmore 417.59012890  GAS DRYER
Kenmore 417.69042990  KENMORE DRYER
Kenmore 417.69042991  DRYER
Kenmore 417.69052990  DRYER
Kenmore 417.69052991  ELECTRIC DRYER
Kenmore 417.79042990  DRYER
Kenmore 417.79042991  DRYER
Kenmore 417.79052990  DRYER
Kenmore 417.79052991  DRYER
Kenmore 417.80032990  DRYER
Kenmore 417.80042990  DRYER
Kenmore 417.80042991  DRYER
Kenmore 417.80052990  DRYER
Kenmore 417.80052991  DRYER
Kenmore 417.80142000  DRYER
Kenmore 417.81042000  DRYER
Kenmore 417.81042001  DRYER
Kenmore 417.81052000  ELECTRIC DRYER
Kenmore 417.81052001  DRYER
Kenmore 417.81142000  DRYER
Kenmore 417.81142001  DRYER
Kenmore 417.82042100  DRYER
Kenmore 417.82042101  DRYER
Kenmore 417.82042102  SEARS/DRYER
Kenmore 417.82052100  DRYER
Kenmore 417.82052101  DRYER
Kenmore 417.82052102  DRYER
Kenmore 417.82052103  SEARS/ELECTRIC DRYER
Kenmore 417.82142100  DRYER
Kenmore 417.82142101  DRYER
Kenmore 417.82142102  SEARS/ELECTRIC DRYER
Kenmore 417.83042200  SEARS/DRYER
Kenmore 417.83042201  SEARS/ELECTRIC DRYER
Kenmore 417.83052200  SEARS/DRYER
Kenmore 417.83052201  SEARS/DRYER
Kenmore 417.83142200  SEARS/DRYER
Kenmore 417.83142201  SEARS/ELECTRIC DRYER
Kenmore 417.88988100  ELECTRIC DRYER
Kenmore 417.88988800  ELECTRIC DRYER
Kenmore 417.88989100  GAS DRYER
Kenmore 417.88989800  GAS DRYER
Kenmore 417.89090100  WASHER DRYER COMBINATION
Kenmore 417.89090110  COMBINATION WASHER-DRYER
Kenmore 417.89090200  WASHER DRYER COMBINATION
Kenmore 417.89090210  COMBINATION WASHER-DRYER
Kenmore 417.89090400  WASHER DRYER COMBINATION
Kenmore 417.89090410  COMBINATION WASHER-DRYER
Kenmore 417.89090600  WASHER DRYER COMBINATION
Kenmore 417.89090610  COMBINATION WASHER-DRYER
Kenmore 417.89090800  WASHER DRYER COMBINATION
Kenmore 417.89090810  COMBINATION WASHER-DRYER
Kenmore 417.90032990  DRYER
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
  #2 (permalink)
Old 12-10-2008, 03:48 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I would reach inside the tub and see if it spins "ok", the spider spin bsket support may just be broken. If ok, pull off the top and check the suspension springs and struts. See if the tub is supported on all sides.
__________________
  #3 (permalink)
Old 12-10-2008, 03:52 AM
Junior Member
Default
Thanks for the tip but I'm not a do-it-yourselfer. I can do the first part at least, and if it spins OK, is it then likely to be a repair that won't cost nearly as much as a new washer?
  #4 (permalink)
Old 12-10-2008, 03:53 AM
Junior Member
Default
Also - my dryer is stacked on top of the washer, if that makes any difference (can't just pull the top off...)
  #5 (permalink)
Old 12-10-2008, 10:14 AM
Senior Expert
APP Volunteer
Default
You can pull the kick panel off under the door and check for suspension parts disconnected. If you find something, you will need to pull the top off to fix.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag top loading washer leaking in spin cycle from bottom kleve Washer Repair 3 07-23-2009 11:12 AM
Front loading washer won't turn/spin pauldw Washer Repair 0 01-04-2009 08:29 AM
GE Profile Front Loading Washer won't spin drhender Washer Repair 1 11-29-2008 02:06 PM
washer out of balance spin cycle mcoffman5 Washer Repair 8 11-12-2008 06:43 AM
banging noise on spin cycle front loading blaise Washer Repair 0 10-04-2008 02:22 PM
