Discuss
Kitchenaid Washer
 in
Washer Repair
When the washer reaches Rinse on the timer, the machine will not advance any further in the cycle. What part
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kitchenaid Washer
  #1 (permalink)
Old 12-09-2008, 01:12 PM
Junior Member
Russ T is on a distinguished road
Default Kitchenaid Washer
Model Number: KAWS850JQ4   Brand: Kitchen Aid   Age: 5 - 10 years
When the washer reaches Rinse on the timer, the machine will not advance any further in the cycle. What part needs to be replaced?
Ads By Google
Related Models
Whirlpool KAWS850JQ4
Whirlpool KAWS850JT0
Whirlpool KAWS850JT1
Whirlpool KAWS850JT2
Whirlpool KAWS850JT3
Whirlpool KAWS850JT4
Whirlpool KAWS850LE0
Whirlpool KAWS850LE1 Automatic Washer
Whirlpool KAWS850LE2 Automatic Washer
Whirlpool KAWS850LQ0
Whirlpool KAWS850LQ1 Automatic Washer
Whirlpool KAWS850LQ2 Automatic Washer
Whirlpool KAWS850LT0
Whirlpool KAWS850LT1 Automatic Washer
Whirlpool KAWS850LT2 Automatic Washer
Whirlpool KAWS855JE0
Whirlpool KAWS855JE1
Whirlpool KAWS855JE2
Whirlpool KAWS855JE3
Whirlpool KAWS855JE4
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC5 6 Qt. Stand Mixer
Whirlpool KB26G1XBU3 6 Qt. Stand Mixer
Whirlpool KB26G1XBU5 6 Qt. Stand Mixer
Whirlpool KB26G1XER3 6 Qt. Stand Mixer
Whirlpool KB26G1XER5 6 Qt. Stand Mixer
Whirlpool KB26G1XGN3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR5 6 Qt. Stand Mixer
Whirlpool KB26G1XMC3 6 Qt. Stand Mixer
Whirlpool KB26G1XMC5 6 Qt. Stand Mixer
Whirlpool KB26G1XMY3 6 Qt. Stand Mixer
Whirlpool KB26G1XMY5 6 Qt. Stand Mixer
Whirlpool KB26G1XOB3 6 Qt. Stand Mixer
Whirlpool KB26G1XOB5 6 Qt. Stand Mixer
Whirlpool KB26G1XPT3 6 Qt. Stand Mixer
Whirlpool KB26G1XPT5 6 Qt. Stand Mixer
Whirlpool KB26G1XTG3 6 Qt. Stand Mixer
Whirlpool KB26G1XTG5 6 Qt. Stand Mixer
Whirlpool KB26G1XWW3 6 Qt. Stand Mixer
Whirlpool KB26G1XWW5 6 Qt. Stand Mixer
Whirlpool KB3SS
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
Frigidaire KB443GDM1 Wwh(v2) / Electric Continuous Clean Oven
Frigidaire KB443GDM2 Wwh(v1) / Electric Range
Frigidaire KB443LM1 Wwh(v1) / Electric Range
Frigidaire KB563LM0 Wwh(v1) / Wall Oven
Frigidaire KB663GDM0 Wwh(v1) / Electric Self - Clean Oven
Frigidaire KB663GDM1 Wwh(v2) / Electric Self - Clean Oven
Frigidaire KB663GDM2 Wwh(v1) / Wall Oven
Frigidaire KB663LM0 Wwh(v1) / Electric Range
Frigidaire KB663LM1 Wwh(v1) / Electric Range
Frigidaire KB663LM2 Wwh(v1) / Electric Range
Frigidaire KB663LMO Wwh(v0) / Electric Range
Frigidaire KB883GDM1 Wwh(v1) / Electric Double Oven W/self Clean Upper
Frigidaire KB883GDM2 Wwh(v1) / Electric Range
Frigidaire KB883GDM3 Wwh(v2) / Electric Range
Frigidaire KB883GDMO Wwh(v2) / Electric Double Oven W/self Clean Upper
Frigidaire KB883LM0 Wwh(v1) / Electric Range
Frigidaire KB883LM1 Wwh(v1) / Electric Range
Frigidaire KB969LM0 Wwh(v1) / Electric Range
Frigidaire KB969LM3 Wwh(v1) / Electric Range
Whirlpool KBAL181TSS00 Access Doors, 18"
Whirlpool KBAR181TSS00 Access Doors, 18"
Whirlpool KBAU272TSS00 Access Doors, 27"
Whirlpool KBAU302TSS00 Access Doors, 30"
Whirlpool KBAU362TSS00 Access Doors, 36"
Whirlpool KBAU482TSS00 Access Doors, 48"
Whirlpool KBBP100LSS0 Built - in Bar Cart 30"
Whirlpool KBC5N
Whirlpool KBC90N
Whirlpool KBCA06XPBL00 Refrigerator
Whirlpool KBCA06XPBL01 Refrigerator
Whirlpool KBCA06XPBS00 Refrigerator
Whirlpool KBCA06XPBS01 Refrigerator
Whirlpool KBCA06XPWH00 Refrigerator
Whirlpool KBCA06XPWH01 Refrigerator
Whirlpool KBCO06XPBL00 Refrigerator
Whirlpool KBCO06XPBL01 Refrigerator
Whirlpool KBCO24LSBX00 Beverage Center
Whirlpool KBCO24RSBX00 Beverage Center
Whirlpool KBCS24LSBS00 Beverage Center
Whirlpool KBCS24RSBS00 Beverage Center
Whirlpool KBCS24RSSS00 Beverage Center
Whirlpool KBDS100T0 Disposer
Maytag KBDS24L92KA  Ref - Sxs
Maytag KBDS24L92KW  Ref - Sxs
Whirlpool KBDS250S0
Whirlpool KBDS250S1
Whirlpool KBDS250T1
Whirlpool KBDS250V0
Whirlpool KBDS250V1
Whirlpool KBDS250V2
Whirlpool KBDS250X
Whirlpool KBDS250X3
Whirlpool KBDS250X4
Whirlpool KBFA20ERBL00 Refrigerator
Whirlpool KBFA20ERBL01 Refrigerator
  #2 (permalink)
Old 12-09-2008, 02:34 PM
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
Does the washer DRAIN? If not, check the LID-Switch, If it does drain, check to see if you get cold water coming into the washer!!!!
__________________
  #3 (permalink)
Old 12-09-2008, 02:38 PM
Junior Member
Default
Yes, the washer will drain if I manually move the dial past the "rinse" mark. The washer will complete its cycle. It seems to get hung up when it hits rinse.
  #4 (permalink)
Old 12-09-2008, 02:52 PM
Senior Expert
APP Volunteer
Default
It sounds like the TIMER has a dead spot in it. The only thing to do is replace the Timer!!! Before you run out and buy a timer, Try 1 of the other cycles, MY guess is that it will go thru the other cycles OK. If it does, REPLACE the TIMER!!!
__________________
  #5 (permalink)
Old 12-09-2008, 02:53 PM
Junior Member
Default
I will try that. Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid washer won't spin Sherry Washer Repair 4 04-19-2013 12:25 PM
Kitchenaid washer jetho69 Washer Repair 3 09-30-2009 01:48 PM
Kitchenaid washer won't spin graciousaint Washer Repair 7 05-19-2009 03:28 PM
Kitchenaid washer drp Forum Announcements 0 02-26-2009 10:58 AM
KitchenAid Washer Won't Spin frankla10 Washer Repair 7 01-24-2009 01:27 AM
