stuck ...
I have reset the reset and it trippped again. the belt on the motor is fine and the motor sounds like it is working, but will not activate the agitator, is this because the motor is fried or the reset switch is fried...
Stuck update:
the motor runs and the timer switch activates with an aligator clip, but still will not agitate. I took the pump asembly apart and there is no obstruction... what now?
Try to manually agitate with the belt.
Nat |
stuck
the agitator turns one way and is restricted the other, I also had gravity feed for it to drain
| All times are GMT -7. The time now is 03:59 PM. |
