Wanted To Know If Wiring Diagram Is Available For A Whirlpool Washer Model Number Lda5700w2, From Around 1976. As For Now, Can You Tell Me Where The Motor Wires Go To What Terminals? There Are Three Wires (not Including The Ground Which Is Green And Is Not Important Now). One Is Blue, One Is Orange (red?) And The Last One Is White. Since I Believe The Motor Is A Two Speed Type, Which Wires Go To Which Terminals On The Two Speed Motor? Is The White Wire A Neutral Wire? I Just Don't Know, And No One Seems To Have A Wiring Diagram. Thanx
I also cold not find a wiring diagram for this unit, it is just too old. I did find the following. http://www.applianceaid.com/image/inglis-belt-diagram.JPGYou should be able to figure out which connection is Neutral (white) with a meter using resistance. Then hook up the other two. If it runs OK then you got lucky. If the speed are wrong reverse the two wires. Hopefully someone else will jump in with better info. |
THIS FORUM IS DEAD!!!!!!! |
